How can I configure the database port for MySQL in the CID lookup?
In my case, the remote database is an Odoo database running on PostgreSQL (port 5432).
Give it a try:
…XXX:5432
Hi @mo10 -
Thanks for your advice—I really appreciate it. It was my first shoot, but unfortunately, it didn’t go as planned.
Also keep in mind: PostgreSQL is not MySQL
Hi @mo10 -
Thanks for your help and support.
I understand that PostgreSQL is not MySQL. However, I can query the database in that language to retrieve the contact name.
I suppose that, in essence, what the system does is assume port 3306 for the connection.
Ideally, the form should have an additional field to configure the remote database port.
As you can see bellow, a MySQL query is working fine from console using psql using port 5432:
