Multi Tenant with subdomains
Is it possible to have a subdomain for each tenant?
On the VitalPbx Multi-Tenant server there are several public IPs available, and I would like each client (each tenant) to be able to access its own interface with its subdomain.
Thanks,
Marcelo
You can for sure assign multiple sub-domains or domains to your PBX. However, all of them should point to the same server and the GUI will be exactly the same.
