Move Calls to Amazon Bucket Article Correction
There is a small typo in this article that will cause it to fail.
Error:
In this file: /etc/fstab
s3fs#pbx3bucket /mnt/s3bucket fuse_netdev,allow_other,passwd_file=/root/.passwd-s3fs,url=https://s3.us-east-2.amazonaws.com,use_cache=/tmp 0 0
This “fuse_netdev” should have been “fuse _netdev”
There should be a space after fuse
Information has been forwarded to support for correction, but if you followed the article and it didn’t work. Here is the change that needs to be made. After this works great.
Your suggestions have been applied to the blog post! Thanks for your contribution!
