Missing Yealink Template for W90DM & W90B
Would it be possible to add a dedicated template for the W90DM and W90B, or alternatively allow the number of accounts in the W70B template to be adjusted?
Thank you for your consideration.
Hello, I was hoping for a update from VitalPBX staff, even if negative. This will allow us to find alternatives. Thank you.
This would be a fantastic feature to have. I know Vital staff in the past have said that you can manually put the extra lines in the config file, but this would be a bit of a pain long term.
The W70b template seems broken anyways.
“account.1.sip_server_host” is not used anymore.
So the following line for the server address:
account.{{ $loop->iteration }}.sip_server_host = {{ $account['sip_domain'] ?? null }}
should be
account.{{ $loop->iteration }}.sip_server.X.address= {{ $account['sip_domain'] ?? null }}
basically, from
account.X.sip_server_host =
to
account.X.sip_server.X.address=
Hello, we’ll add those models for the next update.
That is fantastic news!!! If you can include the W80DMs as well, that would make my whole year!
Ok, we’ll also add the w80dm
Cant wait, thanks so much!!!
Thankyou so much, it seems great - we are looking to deploy this week :slight_smile:
