Migration Elastix to Vitalpbx 3
hello, is this script valid for the latest version of vitalpbx?
No, that script haven’t been tested with VitalPBX 3!
Would it be possible for you to install VitalPBX 2, do the elastix to vpbx migrate. If all is done use the v2 to v3 script. Just an idea.
v2 Iso is here:
http://repo.vitalpbx.org/vitalpbx/isos/vitalpbx-2.4.2-7.iso
Thank you @mo10 :slight_smile:
Did it work or will you test it and report?
I will be testing it in the next few weeks. I’ll document it and post the result here. I still hesitate between adapting the script and your method.
