Migrating Sonata Records from VPBX 3.2 to 4.5
Is there a procedure for manually migrating Sonata Recordings? Due to some errors on a VPBX 3.2 installation I am having to move a client from Centos7 + VPBX 3.2 to a new Debian 12 +4.5 install, but despite all my efforts none of the records are appearing in the GUI.
Update: figured it out. It was an involved process but it’s now working.
Can you please share with everyone what the problem was and how you solved it? Thanks
You can take backup from v3 and restore to v4 without including the recording
Then scp them manually from /var/spool/asterisk/monitor
My problem was that something broke after I interrupted a software update, and I did not want to use the available backup because of some weirdness in not being able to delete a stubbornly undeletable extension because VPBX thought it was in use by a time condition (it wasn’t). I saw it as an opportunity to start fresh, but this client had years of recordings. The whole process was less complicated than I thought it might be.
  • On the old server, did a mysqldump of the asterisk cdr > cdr.sql
  • Moved an external virtual volume of the recordings to a new server, created a symlink to “monitor” on the volume
  • On the new server, imported the cdr.sql file into asterisk mysql -u root -p asterisk < /tmp/cdr.sql
The client wasn’t rating calls or attaching notes, so there was really nothing in rec_recordings.
Fortunately, monitor was on an external volume attached to the VPS. Just needed to reset the top level permissions after I moved the volume to the new server.
Sometimes I love diving in and doing things manually. Other times I wish I could sell this business and relax a little more!
