Method to forward a voicemail?
Is there any way to forward a voicemail to another extension’s voice mailbox?
Are you looking to send to another extension’s voicemail after ringing the previous extension? Or are you looking to forward received voicemails from one extension’s inbox to another?
Just need a little more information.
Just forward to another extension. I have asked for a forward button in WebRTC or the Visual Voicemail screen in Vital but they haven’t adopted it as a feature worth perusing.
When checking the voicemail box, after listening to the message, asterisk gives you the option to forward the voicemail to another user (option 8), then you just have to choose the extension you want to forward to and follow the rest of the prompts.
Would a VM via Email be something you could use?
Easy forwarding there.
Yes … that is better than the old asterisk menu method but requires them to download and then send … and some of my medical assistants don’t use email … check it once in a blue moon. In any case, thanks!
