Listing the extensions with "Call Forward Immediately" (CFI) set
Is there a method, through Web-GUI or CLI, to help us list the extensions with have “Call Forward Immediately” (CFI) set ?
Regrads.
Look under the extension status page.
Hi PitzKey,
Sorry for not being clear enough. I am looking for a method to obtain the list of extensions with CFI set, together with the number specified for forwarding. A CLI command, if available, would be great, as I am planning to create an automatic, perhaps weekly reminder through Crontab, to the administrator.
Thanks in advance.
You could use something like this:
rasterisk -rx ‘database show 63228223c8e82b75 diversions’ | grep ‘/CFI’
63228223c8e82b75 would be your tenant id
you can get the tenant id by just doing database show from the cli
Thank you dannylarsen,
Can you provide more hints on how I can obtain my tenant id ? I am familiar with MySql, but have no clue on the DB structure here.
Regards.
From the asterisk command line, or CLI in the Vitalpbx gui type: database show
There will be many entries with a similar number that is your tenant id
Hi dannylarsen,
I have issued the command and received a huge amount of lines as a response. Below are some of them;
/a9a071d09xx51d62/extensions/2991/absent_secretary: no
/a9a071d09xx51d62/extensions/2991/answermode : disable
/a9a071d09xx51d62/extensions/2991/vmenabled : no
/a9a071d09xx51d62/extensions/2991/voicemail : 2991@vitalpbx-voicemail
First I thought the “a9a071d09xx51d62” was the tenant ip, but then I realized that the sane pattern is also available for all the other extensions too. I also found another group of lines (for each of the extensions) like below ;
/devices/SIP/2991/assigned_exten : 2991
/devices/SIP/2991/emergency_cid :
/devices/SIP/2991/hot_desk : no
/devices/SIP/2991/location :
/devices/SIP/2991/send_push : no
/devices/SIP/2991/tenant : a9a071d09xx51d62
Again, the “tenant” values are the same for every extension. Is there something I am missing ?
Assuming you have only one tenant id, yes this a9a071d09xx51d62 would be it
The command: “database show a9a071d09xx51d62 diversions”
Will show ALL diversions, you will have to use some other mechanism like grep to extract only the CFI entries
