I see that the new Debain Vitalpbx has a limitation of 12 extensions, can you please verify what is a licensed system, can we just buy individual addons or do we need to buy a monthly plan ?
You can remove this restriction by purchasing the Starter license and purchasing a subscription.
Looks like we are slowly moving to a commercial only system
Provisioning module also only supports a small number of extensions
We are not charging per extension, it’s just a limitation for systems that doesn’t have any kind of license.
Activating an Starter License or a subscription will remove this limitation.
Asking for the user to buy only 1 addon is Very reasonable for a pbx of this caliber.
Will Sonata Switchboard disable the limit?
Regards
Pasquale
Starter License will disable the limit! So Sonata Switchboard will as well.
