Lets Encrypt Renew Certificate error
I tried to renew an Lets encrypt certificate, and i got the following error:
In the In the /var/log/vitalpbx/letsencrypt.log file i have this:
[2025-02-04 16:24:29.480129] [debug] GET response received
request: ‘GET https://acme-v02.api.letsencrypt.org/directory’
header: 'HTTP/2 200
server: nginx
date: Tue, 04 Feb 2025 19:24:29 GMT
content-type: application/json
content-length: 828
cache-control: public, max-age=0, no-cache
x-frame-options: DENY
strict-transport-security: max-age=604800
status: 200
body: array(
    'keyChange' => 'https://acme-v02.api.letsencrypt.org/acme/key-change',
    'meta' => array(
        'caaIdentities' => array(
            0 => 'letsencrypt.org',
        'profiles' => array(
            'classic' => 'The same profile you're accustomed to',
        'termsOfService' => 'https://letsencrypt.org/documents/LE-SA-v1.4-April-3-2024.pdf',
        'website' => 'https://letsencrypt.org',
    'newAccount' => 'https://acme-v02.api.letsencrypt.org/acme/new-acct',
    'newNonce' => 'https://acme-v02.api.letsencrypt.org/acme/new-nonce',
    'newOrder' => 'https://acme-v02.api.letsencrypt.org/acme/new-order',
    'renewalInfo' => 'https://acme-v02.api.letsencrypt.org/draft-ietf-acme-ari-03/renewalInfo',
    'revokeCert' => 'https://acme-v02.api.letsencrypt.org/acme/revoke-cert',
    'w1295c5WixY' => 'https://community.letsencrypt.org/t/adding-random-entries-to-the-directory/33417',
[2025-02-04 16:24:29.996212] [debug] HEAD response received
request: ‘HEAD https://acme-v02.api.letsencrypt.org/acme/new-nonce’
header: 'HTTP/2 200
server: nginx
link: https://acme-v02.api.letsencrypt.org/directory;rel=“index”
replay-nonce: aTttXYyySEOY2HO8LMVKDNVupf7ssmJ-L-MsqlmY9ELUJ9R_umw
status: 200
body: ''
[2025-02-04 16:24:29.999108] [info] No account found, attempting to create account.
[2025-02-04 16:24:32.577275] [debug] POST response received
request: ‘POST https://acme-v02.api.letsencrypt.org/acme/new-acct’
header: 'HTTP/2 201
server: nginx
date: Tue, 04 Feb 2025 19:24:32 GMT
content-length: 875
boulder-requester: 2209643605
link: https://letsencrypt.org/documents/LE-SA-v1.4-April-3-2024.pdf;rel=“terms-of-service”
location: https://acme-v02.api.letsencrypt.org/acme/acct/2209643605
replay-nonce: UvlUZ57Po5hOAcTS7PNJNokAvqv56eLcgYqRBASj7xAtupmeejM
status: 201
body: array(
    'key' => array(
        'kty' => 'RSA',
        'n' => '1-uHo58WFQOtmsMuJ5zEKJ4V3WVZrUfuydgRpOytxXod_X851sbifd9sk5KEmIeNqpqBZNF3Y7SRzQPoFYzcFASR53jfTfEQ-Y8l-O4q06u0uOl9LyXb1Yp8XN_ruwLIlWw6dKbGmon7GZxb7UQD9LoSQZaTlh_ZYO2YjXB_FIgvXsGSLIz39YX_QuNuiL97soVtny-2y40uwHD-kIWa8TnbFIpVQGVyVCvmxUOrG5kzFV_ELB3sCtQi3Pc0DAns4E6tGFLiexryWT1F0TLoGq-7_bYX58XrObpBCRRRlEKZpp-aTNT8D8AcH9BxwoeSWgWONcVfvC9NEld-cEMEWRVPaMJjCfl0rhZzk2GAE3Xy33BKlR5jMWuPIHnH6aqaZZ7huCLF_ZpaUFmh9AE30eKKNin5dUYd65WOk351hD3x0e2U6FkxiuWC5lSKqbWshahhJuvZUZHayMo2Jklrznqqj0zcQZdtB_DVJdO_iBuBkWnUGBIQQozVqroH4UwqvwgA-lAN3NmABLooyMQqZLOTPASvUZgAj5je_YLLWbnwhYkQpwn4wWvwGOkVYDalQ6e9ebVeVO-62ujFjBmtBZzIzgh7vwVqxUg78H6UdH8eW-ELV0WNESyhf-h0wMlhJM-HeLRWnV5S65B_iyMSpg1vIsovd4Ivbz9Qrrijwl0',
        'e' => 'AQAB',
    'contact' => array(
        0 => 'mailto:[email protected]',
    'createdAt' => '2025-02-04T19:24:32.477167089Z',
    'status' => 'valid',
[2025-02-04 16:24:33.141096] [debug] POST response received
request: ‘POST https://acme-v02.api.letsencrypt.org/acme/acct/2209643605’
header: 'HTTP/2 200
server: nginx
date: Tue, 04 Feb 2025 19:24:33 GMT
content-length: 808
replay-nonce: TUC11O6XLV7hCblDT8qi6RRusXJfoQBC4M_H3qmTJPSZTgJtoao
status: 200
body: array(
    'key' => array(
        'kty' => 'RSA',
        'e' => 'AQAB',
    'createdAt' => '2025-02-04T19:24:32Z',
If i try to renew the certificate again, the error changes:
In the same letsencrypt.log file i have this now:
[2025-02-04 16:50:13.606534] [debug] GET response received
header: 'HTTP/2 200
server: nginx
date: Tue, 04 Feb 2025 19:50:13 GMT
content-length: 828
status: 200
body: array(
    '_AT4INIA8QY' => 'https://community.letsencrypt.org/t/adding-random-entries-to-the-directory/33417',
    'meta' => array(
[2025-02-04 16:50:14.082468] [debug] HEAD response received
header: 'HTTP/2 200
server: nginx
date: Tue, 04 Feb 2025 19:50:14 GMT
replay-nonce: TUC11O6Xq8HAtYad4csY9rMvSItvUuD7_PILBWfpzYzwiSesGVY
status: 200
body: ''
[2025-02-04 16:50:14.085544] [info] No account found, attempting to create account.
[2025-02-04 16:50:14.977061] [debug] POST response received
header: 'HTTP/2 429
server: nginx
content-type: application/problem+json
content-length: 275
link: https://letsencrypt.org/docs/rate-limits;rel=“help”
replay-nonce: UvlUZ57PunSuF7tGXiq1jrh93076TElk3ptNAqBbOZ9daApcAjg
retry-after: 502
status: 429
body: array(
    'type' => 'urn:ietf:params:acme:error:rateLimited',
    'detail' => 'too many new registrations (10) from this IP address in the last 3h0m0s, retry after 2025-02-04 19:58:37 UTC: see https://letsencrypt.org/docs/rate-limits/#new-registrations-per-ip-address',
    'status' => 429,
I assume this was an error with the account, since the log says “no account found, attempting to create account”. So i deleted the certificate and tried to create a new one, but now i dont have my certificate anymore, and still receiving the same error. Any ideas?
Btw, the vitalpbx.com and helpdesk.vitalpbx.com is down for me, so i cant create a ticket for this issue.
What version of VitalPBX?
System Information
Distro Debian GNU/Linux 11 (bullseye)
Kernel 5.10.0-32-cloud-amd64
PBX Engine 18.23.1
VitalPBX 4.1.0-7
PHP Version 8.1.11
Well, if you did a quick search on the forums you will see that LetsEncrypt issues has been fixed in recent updates.
Please update your PBX to the latest version and report back if you still have the exact same issue.
Thanks! After updating the server, the issue was fixed.
