I followed the guide and installed Let’s Encrypt, and now the SSL issue is resolved. I need to know if it will automatically renew when it expires. Please check the image.
No one knows what guide you followed… Please share the information you followed.
If the port is open, then it should auto renew.
How can i checked port is open?
Where’s the server hosted?
Does your host have an additional firewall in front of the PBX?
There is no additional firewall. The PABX host is on the bare-metal server I purchased, and the data center is not blocking any ports.
Thank you.
Then the certificate will be renewed automatically!
Ok , Thank you Very much ![]()
