Languages Not Working
Good morning,
Having a bit of trouble understanding the language features,
I created a language with destination an extension number.
Does this mean that anything that has to do with that extension will be played in said language?
Cos it keeps remaining in English, i try with the default Spanish as a test.
Have you pointed anything to that language object?
Is this enough to listen on the 61 Extension all menus in Greek?
I try *97 and i hear the English language
No, only when you use the language as a destination, on inbound route for example, the module afterwards will be in that language.
For internal use you can try using custom destination.
Hi mo10, how are you?
Procedure to change the entire language?
Is this correct?
This doesnt work either
Go to your extension and change the Language there.
The general setting is only when you create new extensions.
Please check the Youtube-Channel of Vitalpbx for all the basics that you need.
Thank you my friend,
I missed the section in the extension page.
Time to change the glasses obviously!
Have a good day
