I am noticing that everything I am setting for my FQDN is not reflecting in applications settings and I am not able to access the GUI with my proxy setup. For example, Its showing the phonebook url as 192.168.x.x/xxxx instead of domain/xxxx Not to sure whats wrong. I updated the host name and followed the instructions for using a FQDN. I checked the logs and its making it to the PBX box but then it stops.
Are you accessing the PBX using your FQDN?
The modules display the URL or IP address of the location from which you are accessing them.
No does not work. have to use the local ip.
They show the IP and not the URL.
Issue was firewall rule related.
