My phones are all getting an error when attempting to auto provision.
1026184822|btoe ||00|MsgPpsNcasProcessStartStopCmnd: BTOE is disabled. Cannot start Pairing
1026184822|pps ||00| vqmon process service route is disabled
1026184822|copy ||00|Server ‘xXXXXXXserverdata.com’ said ‘phoneprov/f2171787387b5f74:5060/000000000000.cfg’ is not present
1026184822|cfg |4|00|Prov|File transfer failed due to curl error code:22 and respCode:404
1026184822|cfg |4|00|Prov|Download of master configuration file failed
1026184822|cfg |4|00|Prov|Trying to boot from existing configuration
1026184822|cfg |4|00|Prov|Update configuration failed
1026184822|cfg ||00|Prov|Finished updating configuration
1026184822|copy ||00|Server ‘xXXXXXXserverdata.com’ said ‘phoneprov/f2171787387b5f74:5060/4825670cacbc-app.log’ is not present
1026184822|copy |4|00|Could not set the custom header Content-Range for HTTP/s request. Head request failed to get content-length of server file.
1026184937|so ||00|SCEP feature is disabled.
1026184937|log |4|00|UtilLogServerC::uploadFifoLog: upload error. protocol 0 result = 0
1026184937|pgui ||00|Qt Keyboard driver created.
1026184937|pgui |4|00|Reconnected with core app, reload the keyboard
1026184939|pgui ||00|Qt Mouse driver created.
1026184939|pgui |5|00|Received theme(1) : Existing Theme(-1)
1026184939|app1 ||00|[appInitialized] App initialization is completeled.
1026184939|app1 |5|00|AppExchangeUiC::configSecurity CA path:[/ffs0/ca1.crt]
1026184939|moh ||00|Initial log entry. Current logging level 4
1026184939|so |4|00|[SoNcasC]: appncascontext termination:1
1026184939|so |4|00|[SoNcasC]: Case Handling termination:1
1026184939|sip |4|00|doDnsDeInitDnsStkCache: DNS Cache is not initialized
1026184939|cfg |5|00|Prm|Parameter voIpProt.SIP.tcpFastFailover.timeout requested type 2 but is of type 0
1026184939|sip ||00|Sip registering user:VVX450 display name:VVX 450 authorizing user name:‘’ index value:0
1026184939|utilm|4|00|uBLFUnCompressed: File /ffs0/Config/Local/WebTicket/0/sip.usr doesn’t exist or is empty
1026184939|sip ||00|Fast boot measurement point: ready to make Call, uptime: 38.351 sec.
1026184939|app1 |4|00|Corporate directory is not Enabled.
1026184939|moh |4|00|SoNcasMohC::soNcasmohCfgInit: File provisioning for Music On Hold is defined only for Lync Profile and if Music On Hold feature is enabled
1026184939|cfg ||00|Prov|Starting to provision
1026184939|copy ||00|Server ‘xXXXXXXserverdata.com’ said ‘phoneprov/f2171787387b5f74:5060/4825670cacbc.cfg’ is not present
1026184939|cfg |4|00|Prov|File transfer failed due to curl error code:22 and respCode:404
1026184939|copy ||00|Server ‘xXXXXXXserverdata.com’ said ‘phoneprov/f2171787387b5f74:5060/000000000000-directory.xml’ is not present
1026184940|so ||00|SCEP feature is disabled.
1026184940|copy ||00|Server ‘xXXXXXXserverdata.com’ said ‘phoneprov/f2171787387b5f74:5060/000000000000.cfg’ is not present
1026184940|cfg |4|00|Prov|File transfer failed due to curl error code:22 and respCode:404
1026184940|cfg |4|00|Prov|Download of master configuration file failed
1026184940|cfg |4|00|Prov|Trying to boot from existing configuration
1026184940|cfg |4|00|Prov|Update configuration failed
1026184940|cfg ||00|Prov|Finished updating configuration
1026184940|so |4|00|[MsgSoTR069Init] Start
1026184940|copy ||00|Server ‘xXXXXXXserverdata.com’ said ‘phoneprov/f2171787387b5f74:5060/000000000000-directory.xml’ is not present
1026184940|dectU||00|Initial log entry. Current logging level 4
1026184940|dectU|4|00|DECT_UPDATER SDectUpdaterS0: BaseEventInit: Wait, NotPaired
1026184940|log |4|00|UtilLogServerC::uploadFifoLog: upload error. protocol 0 result = 0
1026184940|log |4|00|Failed to upload boot log on start up.
1026184941|pgui |4|00|Setting new timezone UTC0UTC,J71/2:0:0,J309/2:0:0 for Exchange Calendar
1026184941|pgui |4|00|Stopped access token service
1026184941|copy |*|00|Server ‘xXXXXXXserverdata.com’ said ‘phoneprov/f2171787387b5f74:5060/000000000000-directory.xml’ is not present
