Hello, I wanted to ask if anyone else experienced this:
After upgrading to the latest version of VitalPBX, nginx didn’t apply the HTTPS certificate generated from the online option. I had to manually configure it in the nginx settings.
At the same time, I’m having issues with VitXi:
Incoming calls work fine, with audio in both directions.
But outgoing calls (both external and internal) get disconnected immediately after being answered.
I was able to solve the issue by reloading the certificates in the WebRTC configuration, following the steps from the official manual. After that, I also reviewed the extension profile to ensure it was set correctly.
The only issue I ran into was with the HTTPS certificate used by the web server (nginx). I had to manually configure it there, since the PBX wasn’t applying the changes automatically.
