IPv6 issue port 5060 and 5061
I use VitalPBX Carrier Plus 4.5.0-6
I’ve configured everything for IPv6, including transport settings, through the GUI.
However, as soon as the firewall is enabled, ports 5060 and 5061 (for IPv6) are blocked.
Is there something I need to modify in a configuration file? If so, which one?
Marc
change bining address “::” on pjsip settings
it means 0.0.0.0
Thanks for the answer, but all my extensions and connected trunks are down and won’t reconnect if I do this.
And above all, what does it have to do with the Firewall, because when it’s deactivated, it works.
Hey Marc, were you able to resolve this issue? We’re seeing the same problem with a few of our customers’ PBX systems as well. Let me know if you found a fix!
Hello !
No fix unfortunately.
I will open a ticket when I found some time.
