Integration in AI Voice agent
Hello, I am trying to integrate third party calender calendly under AI Voice agent. I am not able to setup the API Endpoint correctly. There too many parameters and sections which I don’t know how to setup and where to find the information from.
I used AI wizard to setup Real time agent and it was easy but integration; I find it challenging.
Are there any guide or manual I can refer to for third party tool integration?
That’s sort of complex integration due to the Date format expected by calendly. Here’s a basic example:
Get User URI
Get Available Event Types
Thanks Miguel. I will try this out and report back.
