So, I loaded Cent 7 minimum install.
I followed instruction on installing and while running the script I get:
→ Processing Dependency: libboost_program_options.so.1.53.0()(64bit) for package: galera-4-26.4.3-1.rhel7.el7.centos.x86_64
—> Package mariadb-connector-odbc.x86_64 0:3.0.7-1.el7 will be installed
→ Processing Dependency: libc.so.6(GLIBC_2.14)(64bit) for package: mariadb-connector-odbc-3.0.7-1.el7.x86_64
→ Finished Dependency Resolution
Error: Package: MariaDB-compat-10.4.13-1.el7.centos.x86_64 (vpbx-base)
Requires: libc.so.6(GLIBC_2.17)(64bit)
Error: Package: MariaDB-server-10.4.13-1.el7.centos.x86_64 (vpbx-base)
Requires: libsepol >= 2.5-6.el7
Installed: libsepol-2.0.41-4.el6.x86_64 (@anaconda-CentOS-201303020151.x86_64/6.4)
libsepol = 2.0.41-4.el6
Requires: libstdc++.so.6(GLIBCXX_3.4.19)(64bit)
Error: Package: MariaDB-client-10.4.13-1.el7.centos.x86_64 (vpbx-base)
Requires: libstdc++.so.6(GLIBCXX_3.4.15)(64bit)
Error: Package: MariaDB-common-10.4.13-1.el7.centos.x86_64 (vpbx-base)
Requires: libc.so.6(GLIBC_2.14)(64bit)
Requires: libcrypto.so.10(OPENSSL_1.0.2)(64bit)
Error: Package: galera-4-26.4.3-1.rhel7.el7.centos.x86_64 (vpbx-base)
Requires: libstdc++.so.6(GLIBCXX_3.4.18)(64bit)
Requires: libsystemd.so.0(LIBSYSTEMD_209)(64bit)
Requires: libsystemd.so.0()(64bit)
Requires: libboost_program_options.so.1.53.0()(64bit)
Error: Package: mariadb-connector-odbc-3.0.7-1.el7.x86_64 (vpbx-base)
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
root@server2 [~]# → Finished Dependency Resolution
-bash: --: command not found
root@server2 [~]# Error: Package: MariaDB-compat-10.4.13-1.el7.centos.x86_64 (vpbx-base)
-bash: syntax error near unexpected token (' root@server2 [~]# Requires: libc.so.6(GLIBC_2.17)(64bit) -bash: syntax error near unexpected token (’
root@server2 [~]# Error: Package: MariaDB-server-10.4.13-1.el7.centos.x86_64 (vpbx-base)
-bash: syntax error near unexpected token (' root@server2 [~]# Requires: libsepol >= 2.5-6.el7 -bash: Requires:: command not found root@server2 [~]# Installed: libsepol-2.0.41-4.el6.x86_64 (@anaconda-CentOS-201303020151.x86_64/6.4) -bash: syntax error near unexpected token (’
root@server2 [~]# libsepol = 2.0.41-4.el6
-bash: libsepol: command not found
-bash: syntax error near unexpected token (' root@server2 [~]# Requires: libstdc++.so.6(GLIBCXX_3.4.19)(64bit) -bash: syntax error near unexpected token (’
root@server2 [~]# Error: Package: MariaDB-client-10.4.13-1.el7.centos.x86_64 (vpbx-base)
-bash: syntax error near unexpected token (' root@server2 [~]# Requires: libstdc++.so.6(GLIBCXX_3.4.15)(64bit) -bash: syntax error near unexpected token (’
root@server2 [~]# Error: Package: MariaDB-common-10.4.13-1.el7.centos.x86_64 (vpbx-base)
-bash: syntax error near unexpected token (' root@server2 [~]# Requires: libc.so.6(GLIBC_2.14)(64bit) -bash: syntax error near unexpected token (’
-bash: syntax error near unexpected token (' root@server2 [~]# Requires: libcrypto.so.10(OPENSSL_1.0.2)(64bit) -bash: syntax error near unexpected token (’
root@server2 [~]# Error: Package: galera-4-26.4.3-1.rhel7.el7.centos.x86_64 (vpbx-base)
-bash: syntax error near unexpected token (' root@server2 [~]# Requires: libstdc++.so.6(GLIBCXX_3.4.18)(64bit) -bash: syntax error near unexpected token (’
-bash: syntax error near unexpected token (' root@server2 [~]# Requires: libsystemd.so.0(LIBSYSTEMD_209)(64bit) -bash: syntax error near unexpected token (’
-bash: syntax error near unexpected token (' root@server2 [~]# Requires: libsystemd.so.0()(64bit) -bash: syntax error near unexpected token (’
-bash: syntax error near unexpected token (' root@server2 [~]# Requires: libboost_program_options.so.1.53.0()(64bit) -bash: syntax error near unexpected token (’
root@server2 [~]# Error: Package: mariadb-connector-odbc-3.0.7-1.el7.x86_64 (vpbx-base)
-bash: syntax error near unexpected token `(’
root@server2 [~]#
Help!
what did I do wrong?
