I just downloaded the latest release 3.1.0-1 and started to install on hardware which meets the posted requirements X64, 4 core (J4125 celeron), 8GB & 256G, but the install is aborted with an error that the following is needed:
I can load up CentosOS 7 3.10.0-1160.e17.x86_64 minimal using Rufus without issue.
The systems only support UEFI and if I use Balena, they do not detect the USB. If I use Rufus, then they do and begin the startup routine.
Am uncertain if i can load up the version of CentOS 7 I had running and then get the app installed from on top or if the download distro is the only way.
Appreciate any help.
I also tried VitalPBX 3.0.6-2 from Rufus and did not get the grub errors, but continued to get the device mapper error.
Does not look like a USB issue, but rather the system hardware requires some files that are not a part of the distro.
