Insert blacklist numbers into database
Hi;
I would like to import blacklisted numbers directly into the database, the sql syntax is not a problem and the following inserts correctly and appears in the UI when I refresh the page.
INSERT INTO ombu_blacklist (number,description,destination_id,enabled,tenant_id) VALUES('1234567','Test',76,'yes',1);
But is it enough just to insert into the database, or do I also have to execute a script to activate the new entry and pass it to asterisk ??
Many Thanks
You can run
vitalpbx fully-dump-conf
Excellent, thank you so much
