Incoming calls Max duration time
How can I set a Max duration time for incoming calls on Vital PBX ?
You can set a maximum ring time in queues, ring groups, and extensions
If you would like to set a max talk time for incoming calls, you can create a custom dial profile and use the L dial option to set a call timer (See asterisk documentation), and under the extension Advanced tab you will change it to use the custom dial profile.
In this screenshot, I set the max talk time to 20 seconds
Tks for reply me.
BR
