Incoming call Request ‘INVITE’ Failed to authenticate
Hello everyone,
I am a beginner with VitalPbx 4 more used to another well-known one and I have this concern on incoming calls but outgoing no problem.
The only parameter I need to add in another well known “context=from-pstn-toheader”.
But here I am lost
[2023-02-22 11:18:25] NOTICE[20225] res_pjsip/pjsip_distributor.c: Request ‘INVITE’ from ‘“+337XXXXXXXX” sip:[email protected];user=phone’ failed for ‘91.121.129.134:5060’ (callid: [email protected]) - Failed to authenticate
THANKS.
Please share your trunk config, please obfuscate your passwords.
Good morning,
Thank you for your answer, here are screenshots.
Thanks again
Two things you can try
  1. Change the identify order.
  2. Add their IP addresses to the match field
Thanks for the answer,
With OVH French operator, we identify ourselves by the username which is the phone number.
I changed the configuration, it manages to authenticate but I have the following error:
[2023-02-23 19:50:41] SECURITY[1305] res_security_log.c: SecurityEvent=“ChallengeSent”,EventTV=“2023-02-23T19:50:41.028+0100”,Severity=“Informational”,Service=“PJSIP”,EventVersion=“1”,AccountID=“0033XXXXXXXXXX”,SessionID="[email protected]",LocalAddress=“IPV4/UDP/192.168.1.49/5060”,RemoteAddress=“IPV4/UDP/91.121.129.134/5060”,Challenge=“”
That’s not an error.
Good morning,
I just redid vitalpbx and redid the settings, here is the error:
THANKS
[2023-02-25 12:12:24] NOTICE[10787] res_pjsip/pjsip_distributor.c: Request ‘INVITE’ from ‘“+33XXXXXXXX” sip:[email protected];user=phone’ failed for ‘91.121.129.134:5060’ (callid: [email protected]) - Failed to authenticate
[2023-02-25 12:12:24] SECURITY[1585] res_security_log.c: SecurityEvent=“ChallengeResponseFailed”,EventTV=“2023-02-25T12:12:24.796+0100”,Severity=“Error”,Service=“PJSIP”,EventVersion=“1”,AccountID=“0033XXXXXXX”,SessionID=“[email protected]”,LocalAddress=“IPV4/UDP/192.168.1.49/5060”,RemoteAddress=“IPV4/UDP/91.121.129.134/5060”,Challenge=“1677323544/426777f4a076b5fec8ba65e56eec0ee8”,Response=“56ebc556ce234753c410564eede451bd”,ExpectedResponse=“”
hi
you have to add math filed.
스크린샷 2023-02-26 오전 12.12.19
Hello, norman_namkoong
Thank you for your help, but I just tried it does not work.
I try otherwise.
THANKS.
cheer up!
anyway test with SNGREP! more helpfull.
@PitzKey @norman_namkoong
Good morning;
Thank you for your help, after a lot of testing I went back to version 3.2 then I created in SIP with the following parameters:
:innocent:it works very well on incoming and outgoing calls.
It does not work PJSIP it bothers me, yet I use it very well with your competitor in PJSIP surely a setting.
Good day
Hi aero37,
Good job buddy !
This doesnt help - @norman_namkoong
He went back to 3.0 to use chan_sip, i dont want to do that. Can someone post a todo on how to add this type of simple “insecure=port,invite” into 4.0 for pjsip? some simple tutorial?
Hi @Phonestream_LLC and welcome to the forums
Please create a new post describing your issue in detail
