Inaccurate outgoing calls report when Follow-Me is on
When Follow Me is enabled, the outgoing call report shows incoming calls directed to the Follow Me as outgoing calls.
This makes it difficult to differentiate between actual outgoing calls and incoming calls forwarded by Follow Me in the report.
Is there a way to resolve this?
What app are you referring to? Do you have some screenshots from the report?
When using Follow Me, stats will show all calls for the Follow Me number as outgoing calls from this extension
