I can not fix this
i find it but not change. always english
vitalpbx.search =
vitalpbx.pagination.entries =
vitalpbx.pagination.next =
vitalpbx.pagination.previous =
I can not fix this
vitalpbx.search =
What language are you using?
Hi miguel,
I use korean (ko-kr).
thanks
Have you shared your translation in the VitalPBX i18n repo?
HI, miguel
I am working on it. not finished now.
i will share when i finished.
here is some files for test PDF and pagination
vitalpbx.txt (13.7 KB)
repcdr.txt (3.0 KB)
For the CDR table, you don’t need to translate it. The translations are provided in JSON format, so we will add the Korean translations in the next version of VitalPBX.
Hi, miguel
Thanks for reply
now, i got new version
it is perfact working
thanks
I can not fix this
i am using ko-KR
here is screen shot
thanks
hi
i found this, but i can not change to korean
here is screen
www/resources/js/modules/provisioning.js: text: ’ Add Device’,
how could i chang this?
hi,
it is from javascript , how cloud i change it ?
www/resources/js/vendor/33-jquery-ui-multiselect.js: addAll:‘Add all’,
here is screen
Hey @norman_namkoong I moved all your posts to this mega thread.
Please post all your i18n related issues in this topic.
Hi PitzKey
Thanks for your help!
