i need to renew my certificates on letsencrypt ,I installed certbot but,do not renew nothing,what can i do???,the cerificates was made on gui mode
Renewal should be automatic once you create a LE cert from the GUI, if automatic renewal or manual renewal are not working for you, check your firewall and make sure port 80 is open to any in order for the LE renewal process to work.
thanks,i solved,running the scripts,that are ready in /usr/share/vitalpbx/scripts/…
