Hello, You will find under this link a documentation allowing to supervise your IPBX VitalPBX with Zabbix I remain with the listening of any idea of optimization.
Merci beaucoup Sebastian!
hello, you will find below a new article integrating zabbix proxy in active mode in order to monitor vitalpbx without creating a nat rule on the client’s firewall and the supervision of vitalpbx with zabbix agent2 and AMI.
https://wiki.slemoal.fr/index.php/Zabbix_Agent_VitalPBX_proxy
If the Zabbix proxy version should match the server version, then which Zabbix template do you use? The Asterisk template I found and imported requires Zabbix server 5.4. I’ve been working to get this configured and have not had much luck.
Zabbix server: 6.0.0alpha4
Zabbix_proxy V 5.4.7-1
Vitalpbx 3.1.2-1
The templates I use are already integrated into Zabbix, I did not have to import them.
follow all the steps in my article, it should work. I integrated 6 vitalpbx server today by precisely following the steps one by one. if you have a problem do not hesitate to describe it to me more precisely.
