Migrating from VitalPBX 3 to VitalPBX 4 can seem like a daunting task, but with the help of the Backup and Restore module, the process can be simplified. Here are the steps you need to follow to make the transition to VitalPBX 4 as seamless as possible:
- Install VitalPBX 4 on a new server (Only Debian 11 “bullseye” Supported by Now!).
- Install the add-ons that you are using on VitalPBX 3.
- Complete the wizard of add-ons like Switchboard, Recordings, Stats, Dialer, etc.VPN
- Configure and enable the OpenVPN server on VitalPBX 4 if installed on VitalPBX 3.
- Update your VitalPBX 3 to the latest version.
- Get a backup of your VitalPBX 3.
- Release the license from your VitalPBX 3.
- Turn off your VitalPBX 3 Server to avoid issues related to trunk connectivity during the migration.
- Activate the license in your VitalPBX 4 Server.
- Import the Backup from v3 to your VitalPBX 4.
By following these steps, you can successfully migrate from VitalPBX 3 to VitalPBX 4 using the Backup and Restore module.
