How to install Festival Text to Speech (TTS) in VitalPBX
Festival translates the text into speech and can be used on the VitalPBX dial plan.
Installation
Copy install.sh to your home directory and procedure to execute.
cd /
wget https://raw.githubusercontent.com/VitalPBX/pico2wave/master/install.sh
chmod +x install.sh
./install.sh
Voice Select
If you want to change the voice you must go to the voice configuration files that is in:
/usr/share/festiva/lib
Edit the voices.scm file and near line 328 will show the list of available voices, order in such a way that the first one will be the one we hear.
After selecting the voice, the festival service must be restarted:
systemctl restart festival.service
Now Dial
*8866
You should hear the following sentence
This is a simple Vital P B X text to speech test in english.
