Executing [044393585@trk-7-dial:18] NoOp(“SIP/044393585-00000002”, “”) in new stack
– Executing [044393585@trk-7-dial:19] NoOp(“SIP/044393585-00000002”, “Configuring Trunk Parameters”) in new stack
– Executing [044393585@trk-7-dial:20] ExecIf(“SIP/044393585-00000002”, “1?Set(CHANNEL(musicclass)=default):”) in new stack
– Executing [044393585@trk-7-dial:21] Set(“SIP/044393585-00000002”, “__TRUNK_MOH_SET=yes”) in new stack
– Executing [044393585@trk-7-dial:22] Set(“SIP/044393585-00000002”, “DIAL_PREFIX=”) in new stack
– Executing [044393585@trk-7-dial:23] Set(“SIP/044393585-00000002”, “__TRKDIALOPTIONS=kKtr”) in new stack
– Executing [044393585@trk-7-dial:24] Set(“SIP/044393585-00000002”, “ORIGINATOR=0954018856”) in new stack
– Executing [044393585@trk-7-dial:25] Set(“SIP/044393585-00000002”, “RING_TIME=90”) in new stack
– Executing [044393585@trk-7-dial:26] Set(“SIP/044393585-00000002”, “CALLED=044393585”) in new stack
– Executing [044393585@trk-7-dial:27] Set(“SIP/044393585-00000002”, “TRUNK_ENDPOINT=Cisco”) in new stack
– Executing [044393585@trk-7-dial:28] Set(“SIP/044393585-00000002”, “__CIDNUM=0954018856”) in new stack
– Executing [044393585@trk-7-dial:29] Set(“SIP/044393585-00000002”, “__CIDNAME=0954018856”) in new stack
– Executing [044393585@trk-7-dial:30] Set(“SIP/044393585-00000002”, “FORCE_RECORDING=no”) in new stack
– Executing [044393585@trk-7-dial:31] Set(“SIP/044393585-00000002”, “FILTERED_NUMBER=044393585”) in new stack
– Executing [044393585@trk-7-dial:32] GotoIf(“SIP/044393585-00000002”, “0?:post-fax”) in new stack
– Goto (trk-7-dial,044393585,35)
– Executing [044393585@trk-7-dial:35] NoOp(“SIP/044393585-00000002”, “End Fax Section”) in new stack
– Executing [044393585@trk-7-dial:36] Dial(“SIP/044393585-00000002”, “SIP/Cisco/044393585,90,kKtrU(sub-before-bridging-call^68c5bde62ddee288^0954018856^044393585^no)”) in new stack
== Using SIP RTP TOS bits 184
== Using SIP RTP CoS mark 5
– Called SIP/Cisco/044393585
– SIP/Cisco-00000003 is ringing
== Spawn extension (trk-7-dial, 044393585, 36) exited non-zero on ‘SIP/044393585-00000002’
– Executing [h@trk-7-dial:1] GosubIf(“SIP/044393585-00000002”, “0?sub-outbound-queue-call,s,1”) in new stack
– Executing [h@trk-7-dial:2] Gosub(“SIP/044393585-00000002”, “dynamic-routing-out,s,1(0954018856,044393585,CANCEL,7)”) in new stack
– Executing [s@dynamic-routing-out:1] NoOp(“SIP/044393585-00000002”, “Test if save on dynamic routing list”) in new stack
– Executing [s@dynamic-routing-out:2] Set(“SIP/044393585-00000002”, “CALLER=0954018856”) in new stack
– Executing [s@dynamic-routing-out:3] Set(“SIP/044393585-00000002”, “CALLED=044393585”) in new stack
– Executing [s@dynamic-routing-out:4] Set(“SIP/044393585-00000002”, “STATUS=CANCEL”) in new stack
– Executing [s@dynamic-routing-out:5] Set(“SIP/044393585-00000002”, “TRKID=7”) in new stack
– Executing [s@dynamic-routing-out:6] Set(“SIP/044393585-00000002”, “ALLOW_DR=”) in new stack
– Executing [s@dynamic-routing-out:7] Set(“SIP/044393585-00000002”, “DYNROUTING_OMC=yes”) in new stack
– Executing [s@dynamic-routing-out:8] GotoIf(“SIP/044393585-00000002”, “0?:comeback”) in new stack
– Goto (dynamic-routing-out,s,10)
– Executing [s@dynamic-routing-out:10] Return(“SIP/044393585-00000002”, “”) in new stack
– Executing [h@trk-7-dial:3] Gosub(“SIP/044393585-00000002”, “notify-trunk-hangup,s,1”) in new stack
– Executing [s@notify-trunk-hangup:1] Verbose(“SIP/044393585-00000002”, “0, Trunk Hangup”) in new stack
Trunk Hangup
– Executing [s@notify-trunk-hangup:2] Set(“SIP/044393585-00000002”, “CALLER=0954018856”) in new stack
– Executing [s@notify-trunk-hangup:3] UserEvent(“SIP/044393585-00000002”, ““EXTENSIONS_SUMMARY”,“Data: OUTBOUND,0954018856,TRANSIT””) in new stack
– Executing [s@notify-trunk-hangup:4] Return(“SIP/044393585-00000002”, “”) in new stack
– Executing [h@trk-7-dial:4] Hangup(“SIP/044393585-00000002”, “”) in new stack
== Spawn extension (trk-7-dial, h, 4) exited non-zero on ‘SIP/044393585-00000002’
Ahoy @Natapon_Arm and welcome to the forums
Respectfully, creating duplicate posts with random dumps of logs discourses anyone reading through it and providing helpful information.
Kindly, please edit your posts and describe your issue in detail. If you choose to share logs, please do so via pastebin.com, that’s the easiest to read, point out lines, etc. However, it you don’t want to do so, at least format them with pre-formatted text.
