How to configure 10-channel SIP trunk with fixed IP
How to configure, on Vitalpbx, a 10-channel SIP trunk connected to the provider via a fixed IP address?
The operator provided me with the IP for the pabx, on the second network card, with address 172.16.25.66/29, outgoing proxy 192.168.25.1, plus pilot number 213529XXXX, with the instruction: “When making outgoing calls, always send us the A’s number (213529XXXX) with 10 digits; if something different is sent, the call will not go through. Do not enter a password, but if the pabx requires it, simply configure the pilot number 213529XXXX as login.”
I put the proxy IP 192.168.25.1 in the Remote Host field, Local Username the pilot number 213529XXXX, in Match the network 192.168.25.0/24 (without this I won’t receive calls). In Pbx Report > Pjsip Endpoints > Trunks, the value sip:[email protected]:5060 appears as connected.
What else do I need to configure, as I can’t make outgoing calls, only receive them? The company providing the service carried out tests on the client with the MicroSip application, and everything works well.
I thank the attention.
PS: I created the route 192.168.25.0/24 on Linux for the gateway 172.16.25.65/29, as requested by the service provider.
