Yealink has a feature where we can add force.voice.ring_vol = to the phone template to control the ringer volume. Can anyone advise where I can add this to a template in the new provisioning settings?
Thank you,
Thank you,
Are you using the Phone Provisiong add-on? or the EPM add-on?
I am using the Phone Provisioning add-on
I see the custom tab and but I am not sure where inside the custom area and in what format. The config info doesn’t appear in the format of force.voice.ring_vol =
You should get the format from the Yealink documentation.
What do they recommend?
What phone model are you provisioning?
You can find that parameter in the call configuration section in the provision file, the parameter takes an integer value from 0 to 15.
You can find detailed documentation on this link https://support.yealink.com/en/portal/docDetail?documentCode=a797876fad6e607d
These models support that feature T57W,T54W,T53W,T53,T53C,T48U,T46U,T43U,T42U,T48S,T46S,T42S,T41S,T33P,T33G,T31P,T31G,T31,T30P,T30,T27G and CP920
Sorry for the slow response. Thank you very much.
