High availability
We tried to use version 4 of this vitalpbx and successfully configured the HA. however could you please confirm if the behaviour is correct
I established a call (extension to extension) and then we disconnected the primary vitalpbx to the network. the call was dropped which I need to redial it to establish it again
Is there a way to maintain the call even when the primary server is disconnected from the network?
I mean can we configure the HA as active/active so that when primary server is down the existing call will just mirror on the secondary and the call will not dropped
