Help with specific number
Hi forum,
when I try to reach a specific number in germany, the system ends the call immediately after the answer.
By dialing from another PBX and line I can hear that there is a welcome announcement. This is not recognized by my vitalPBX.
Here is the number: +49 2161 19060474
Here is the log:
vitalpbxCLI>
– Executing [0216119060474@cos-Administration:1] NoOp(“PJSIP/19-0000016e”, “More than on digit pattern”) in new stack
– Executing [0216119060474@cos-Administration:2] Gosub(“PJSIP/19-0000016e”, “s,1(0216119060474)”) in new stack
– Executing [s@cos-Administration:1] Set(“PJSIP/19-0000016e”, “EXTENSION=0216119060474”) in new stack
– Executing [s@cos-Administration:2] NoOp(“PJSIP/19-0000016e”, “Dialing 0216119060474 from 19”) in new stack
– Executing [s@cos-Administration:3] Gosub(“PJSIP/19-0000016e”, “sub-set-global-vars,s,1(7e6ec33c5d155b8a,0216119060474,parking-1)”) in new stack
– Executing [s@sub-set-global-vars:1] NoOp(“PJSIP/19-0000016e”, “Setting Global Vars”) in new stack
– Executing [s@sub-set-global-vars:2] Set(“PJSIP/19-0000016e”, “TENANT_PATH=7e6ec33c5d155b8a”) in new stack
– Executing [s@sub-set-global-vars:3] Set(“PJSIP/19-0000016e”, “PREFIX=”) in new stack
– Executing [s@sub-set-global-vars:4] Set(“PJSIP/19-0000016e”, “__PICKUPMARK=0216119060474”) in new stack
– Executing [s@sub-set-global-vars:5] Set(“PJSIP/19-0000016e”, “__PARKINGLOT=parking-1”) in new stack
– Executing [s@sub-set-global-vars:6] Set(“PJSIP/19-0000016e”, “__DYNAMIC_FEATURES=custom-features”) in new stack
– Executing [s@sub-set-global-vars:7] Set(“PJSIP/19-0000016e”, “ICALL=no”) in new stack
– Executing [s@sub-set-global-vars:8] Return(“PJSIP/19-0000016e”, “”) in new stack
– Executing [s@cos-Administration:4] Gosub(“PJSIP/19-0000016e”, “sub-set-call-vars,s,1(7e6ec33c5d155b8a,0216119060474,1,cos-Administration,ARS-all)”) in new stack
– Executing [s@sub-set-call-vars:1] NoOp(“PJSIP/19-0000016e”, “Setting Call Vars”) in new stack
– Executing [s@sub-set-call-vars:2] Set(“PJSIP/19-0000016e”, “_TENANT=7e6ec33c5d155b8a”) in new stack
– Executing [s@sub-set-call-vars:3] Set(“PJSIP/19-0000016e”, “_CALL_DESTINATION=0216119060474”) in new stack
– Executing [s@sub-set-call-vars:4] Set(“PJSIP/19-0000016e”, “_COS_ID=1”) in new stack
– Executing [s@sub-set-call-vars:5] Set(“PJSIP/19-0000016e”, “_COS_NAME=cos-Administration”) in new stack
– Executing [s@sub-set-call-vars:6] Set(“PJSIP/19-0000016e”, “__TRANSFER_CONTEXT=cos-Administration”) in new stack
– Executing [s@sub-set-call-vars:7] Set(“PJSIP/19-0000016e”, “_ARS=ARS-all”) in new stack
– Executing [s@sub-set-call-vars:8] Set(“PJSIP/19-0000016e”, “CDR(tenant)=vitalpbx”) in new stack
– Executing [s@sub-set-call-vars:9] Set(“PJSIP/19-0000016e”, “CDR(destination)=0216119060474”) in new stack
– Executing [s@sub-set-call-vars:10] Set(“PJSIP/19-0000016e”, “CDR(trunk)=”) in new stack
– Executing [s@sub-set-call-vars:11] Set(“PJSIP/19-0000016e”, “CDR(did)=”) in new stack
– Executing [s@sub-set-call-vars:12] Set(“PJSIP/19-0000016e”, “__CALLID=1639384008.1479”) in new stack
– Executing [s@sub-set-call-vars:13] ExecIf(“PJSIP/19-0000016e”, “0?Set(CHANNEL(language)=)”) in new stack
– Executing [s@sub-set-call-vars:14] Return(“PJSIP/19-0000016e”, “”) in new stack
– Executing [s@cos-Administration:5] Gosub(“PJSIP/19-0000016e”, “sub-construct-cid,s,1”) in new stack
– Executing [s@sub-construct-cid:1] NoOp(“PJSIP/19-0000016e”, “Building CID”) in new stack
– Executing [s@sub-construct-cid:2] Set(“PJSIP/19-0000016e”, “_CALL_SOURCE=19”) in new stack
– Executing [s@sub-construct-cid:3] Set(“PJSIP/19-0000016e”, “_CS=19”) in new stack
– Executing [s@sub-construct-cid:4] GotoIf(“PJSIP/19-0000016e”, “0?return”) in new stack
– Executing [s@sub-construct-cid:5] Gosub(“PJSIP/19-0000016e”, “sub-get-device-tree,s,1”) in new stack
– Executing [s@sub-get-device-tree:1] NoOp(“PJSIP/19-0000016e”, “Configuring Device Tree”) in new stack
– Executing [s@sub-get-device-tree:2] Set(“PJSIP/19-0000016e”, “DEV_TECHNOLOGY=PJSIP”) in new stack
– Executing [s@sub-get-device-tree:3] GosubIf(“PJSIP/19-0000016e”, “0?s-local,1”) in new stack
– Executing [s@sub-get-device-tree:4] GotoIf(“PJSIP/19-0000016e”, “0?return”) in new stack
– Executing [s@sub-get-device-tree:5] GotoIf(“PJSIP/19-0000016e”, “1?pjsip”) in new stack
– Goto (sub-get-device-tree,s,9)
– Executing [s@sub-get-device-tree:9] NoOp(“PJSIP/19-0000016e”, “A PJSIP”) in new stack
– Executing [s@sub-get-device-tree:10] Set(“PJSIP/19-0000016e”, “DEV_USER=19”) in new stack
– Executing [s@sub-get-device-tree:11] Goto(“PJSIP/19-0000016e”, “build_interface”) in new stack
– Goto (sub-get-device-tree,s,13)
– Executing [s@sub-get-device-tree:13] Set(“PJSIP/19-0000016e”, “_INTERFACE=PJSIP/19”) in new stack
– Executing [s@sub-get-device-tree:14] Set(“PJSIP/19-0000016e”, “DEV_TREE=devices/PJSIP/19”) in new stack
– Executing [s@sub-get-device-tree:15] Return(“PJSIP/19-0000016e”, “”) in new stack
– Executing [s@sub-construct-cid:6] GotoIf(“PJSIP/19-0000016e”, “0?return”) in new stack
– Executing [s@sub-construct-cid:7] Set(“PJSIP/19-0000016e”, “_CALL_SOURCE=19”) in new stack
– Executing [s@sub-construct-cid:8] Set(“PJSIP/19-0000016e”, “_CS=19”) in new stack
– Executing [s@sub-construct-cid:9] ExecIf(“PJSIP/19-0000016e”, “1?Set(CALLERID(all)=“T57W” <19>)”) in new stack
– Executing [s@sub-construct-cid:10] Set(“PJSIP/19-0000016e”, “_CID_CONSTRUCTED=yes”) in new stack
– Executing [s@sub-construct-cid:11] NoOp(“PJSIP/19-0000016e”, “”) in new stack
– Executing [s@sub-construct-cid:12] Set(“PJSIP/19-0000016e”, “CDR(source)=19”) in new stack
– Executing [s@sub-construct-cid:13] Return(“PJSIP/19-0000016e”, “”) in new stack
– Executing [s@cos-Administration:6] Gosub(“PJSIP/19-0000016e”, “set-global-tenant-vars,s,1”) in new stack
– Executing [s@set-global-tenant-vars:1] NoOp(“PJSIP/19-0000016e”, “Setting Global Vars for vitalpbx Tenant”) in new stack
– Executing [s@set-global-tenant-vars:2] Set(“PJSIP/19-0000016e”, “__TENANT_PATH=7e6ec33c5d155b8a”) in new stack
– Executing [s@set-global-tenant-vars:3] Set(“PJSIP/19-0000016e”, “__TENANT_PREFIX=”) in new stack
– Executing [s@set-global-tenant-vars:4] Set(“PJSIP/19-0000016e”, “__QUEUE_AGENTS_CONTEXT=queue-call-to-agents”) in new stack
– Executing [s@set-global-tenant-vars:5] Set(“PJSIP/19-0000016e”, “__FOLLOWME_CONTEXT=ext-followme”) in new stack
– Executing [s@set-global-tenant-vars:6] Set(“PJSIP/19-0000016e”, “__HINTS_CONTEXT=extension-hints”) in new stack
– Executing [s@set-global-tenant-vars:7] Set(“PJSIP/19-0000016e”, “__DEFAULT_COS=cos-Administration”) in new stack
– Executing [s@set-global-tenant-vars:8] Return(“PJSIP/19-0000016e”, “”) in new stack
– Executing [s@cos-Administration:7] GotoIf(“PJSIP/19-0000016e”, “0?local-dialing”) in new stack
– Executing [s@cos-Administration:8] NoOp(“PJSIP/19-0000016e”, “Check if is an Emergency Call”) in new stack
– Executing [s@cos-Administration:9] GotoIf(“PJSIP/19-0000016e”, “0?emergency-calls,0216119060474,1”) in new stack
– Executing [s@cos-Administration:10] Gosub(“PJSIP/19-0000016e”, “sub-lockphone-check,s,1”) in new stack
– Executing [s@sub-lockphone-check:1] NoOp(“PJSIP/19-0000016e”, “SUB: LOCK PHONE CHECK”) in new stack
– Executing [s@sub-lockphone-check:2] GotoIf(“PJSIP/19-0000016e”, “0?unlock”) in new stack
– Executing [s@sub-lockphone-check:3] GotoIf(“PJSIP/19-0000016e”, “0?unlock”) in new stack
– Executing [s@sub-lockphone-check:4] GotoIf(“PJSIP/19-0000016e”, “0?unlock”) in new stack
– Executing [s@sub-lockphone-check:5] GotoIf(“PJSIP/19-0000016e”, “0?unlock”) in new stack
– Executing [s@sub-lockphone-check:6] GotoIf(“PJSIP/19-0000016e”, “0?:unlock”) in new stack
– Goto (sub-lockphone-check,s,12)
– Executing [s@sub-lockphone-check:12] Return(“PJSIP/19-0000016e”, “”) in new stack
– Executing [s@cos-Administration:11] Gosub(“PJSIP/19-0000016e”, “sub-local-dialing,s,1”) in new stack
– Executing [s@sub-local-dialing:1] NoOp(“PJSIP/19-0000016e”, “Trying to determine if is a local extension”) in new stack
– Executing [s@sub-local-dialing:2] GotoIf(“PJSIP/19-0000016e”, “0?:return”) in new stack
– Goto (sub-local-dialing,s,5)
– Executing [s@sub-local-dialing:5] Return(“PJSIP/19-0000016e”, “”) in new stack
– Executing [s@cos-Administration:12] GotoIf(“PJSIP/19-0000016e”, “0?end-call”) in new stack
– Executing [s@cos-Administration:13] Goto(“PJSIP/19-0000016e”, “cos-Administration-post,0216119060474,1”) in new stack
– Goto (cos-Administration-post,0216119060474,1)
– Executing [0216119060474@cos-Administration-post:1] NoOp(“PJSIP/19-0000016e”, “Outbound Route: outbound asq”) in new stack
– Executing [0216119060474@cos-Administration-post:2] Gosub(“PJSIP/19-0000016e”, “sub-setup-call-type,s,1(outgoing)”) in new stack
– Executing [s@sub-setup-call-type:1] NoOp(“PJSIP/19-0000016e”, “Determinating Call Type”) in new stack
– Executing [s@sub-setup-call-type:2] GotoIf(“PJSIP/19-0000016e”, “0?return”) in new stack
– Executing [s@sub-setup-call-type:3] Gosub(“PJSIP/19-0000016e”, “s-outgoing,1()”) in new stack
– Executing [s-outgoing@sub-setup-call-type:1] NoOp(“PJSIP/19-0000016e”, “Outgoing Call”) in new stack
– Executing [s-outgoing@sub-setup-call-type:2] Set(“PJSIP/19-0000016e”, “__CALL_TYPE=3”) in new stack
– Executing [s-outgoing@sub-setup-call-type:3] Set(“PJSIP/19-0000016e”, “__CALL_TYPE_LABEL=OUT”) in new stack
– Executing [s-outgoing@sub-setup-call-type:4] GosubIf(“PJSIP/19-0000016e”, “0?s-transit,1”) in new stack
– Executing [s-outgoing@sub-setup-call-type:5] Return(“PJSIP/19-0000016e”, “”) in new stack
– Executing [s@sub-setup-call-type:4] Set(“PJSIP/19-0000016e”, “__CALL_TYPE_CONFIGURED=yes”) in new stack
– Executing [s@sub-setup-call-type:5] Set(“PJSIP/19-0000016e”, “CDR(calltype)=3”) in new stack
– Executing [s@sub-setup-call-type:6] Return(“PJSIP/19-0000016e”, “”) in new stack
– Executing [0216119060474@cos-Administration-post:3] Set(“PJSIP/19-0000016e”, “DNID=0216119060474”) in new stack
– Executing [0216119060474@cos-Administration-post:4] NoOp(“PJSIP/19-0000016e”, “Start to Dial Trunks”) in new stack
– Executing [0216119060474@cos-Administration-post:5] Goto(“PJSIP/19-0000016e”, “s-1,1”) in new stack
– Goto (cos-Administration-post,s-1,1)
– Executing [s-1@cos-Administration-post:1] Set(“PJSIP/19-0000016e”, “__CONFIGURED_BY_TENANT=yes”) in new stack
– Executing [s-1@cos-Administration-post:2] Gosub(“PJSIP/19-0000016e”, “sub-construct-cid,s-external,1”) in new stack
– Executing [s-external@sub-construct-cid:1] NoOp(“PJSIP/19-0000016e”, “Setting External CID”) in new stack
– Executing [s-external@sub-construct-cid:2] Set(“PJSIP/19-0000016e”, “EXTENSION_NUMBER=19”) in new stack
– Executing [s-external@sub-construct-cid:3] GotoIf(“PJSIP/19-0000016e”, “0?return”) in new stack
– Executing [s-external@sub-construct-cid:4] GotoIf(“PJSIP/19-0000016e”, “0?return”) in new stack
– Executing [s-external@sub-construct-cid:5] Set(“PJSIP/19-0000016e”, “EMERGENCY_CALL=no”) in new stack
– Executing [s-external@sub-construct-cid:6] Set(“PJSIP/19-0000016e”, “EXTENSION_EMERGENCY_CID=”) in new stack
– Executing [s-external@sub-construct-cid:7] Set(“PJSIP/19-0000016e”, “DYNAMIC_EXTERNAL_CID=no”) in new stack
– Executing [s-external@sub-construct-cid:8] ExecIf(“PJSIP/19-0000016e”, “1?Set(EXTENSION_EMERGENCY_CID=)”) in new stack
– Executing [s-external@sub-construct-cid:9] ExecIf(“PJSIP/19-0000016e”, “1?Set(DYNAMIC_EXTERNAL_CID=no)”) in new stack
– Executing [s-external@sub-construct-cid:10] GotoIf(“PJSIP/19-0000016e”, “0?check-emergency”) in new stack
– Executing [s-external@sub-construct-cid:11] Set(“PJSIP/19-0000016e”, “EXTENSION_EXTERNAL_CID=“4960819263119” <4960819263119>”) in new stack
– Executing [s-external@sub-construct-cid:12] ExecIf(“PJSIP/19-0000016e”, “1?Set(CALLERID(all)=“4960819263119” <4960819263119>)”) in new stack
– Executing [s-external@sub-construct-cid:13] GotoIf(“PJSIP/19-0000016e”, “1?:check-emergency”) in new stack
– Executing [s-external@sub-construct-cid:14] Set(“PJSIP/19-0000016e”, “TENANT_DEFAULT_EXTERNAL_CID=”) in new stack
– Executing [s-external@sub-construct-cid:15] ExecIf(“PJSIP/19-0000016e”, “0?Set(CALLERID(all)=)”) in new stack
– Executing [s-external@sub-construct-cid:16] GotoIf(“PJSIP/19-0000016e”, “0?:info”) in new stack
– Goto (sub-construct-cid,s-external,24)
– Executing [s-external@sub-construct-cid:24] NoOp(“PJSIP/19-0000016e”, “CID Name: 4960819263119, CID Number: 4960819263119”) in new stack
– Executing [s-external@sub-construct-cid:25] Set(“PJSIP/19-0000016e”, “SEND_CID=yes”) in new stack
– Executing [s-external@sub-construct-cid:26] ExecIf(“PJSIP/19-0000016e”, “0?Set(CALLERID(name-pres)=prohib_passed_screen)”) in new stack
– Executing [s-external@sub-construct-cid:27] ExecIf(“PJSIP/19-0000016e”, “0?Set(CALLERID(num-pres)=prohib_passed_screen)”) in new stack
– Executing [s-external@sub-construct-cid:28] Set(“PJSIP/19-0000016e”, “__EXT_CID_CONSTRUCTED=yes”) in new stack
– Executing [s-external@sub-construct-cid:29] Set(“PJSIP/19-0000016e”, “CDR(source)=19”) in new stack
– Executing [s-external@sub-construct-cid:30] Return(“PJSIP/19-0000016e”, “”) in new stack
– Executing [s-1@cos-Administration-post:3] Gosub(“PJSIP/19-0000016e”, “trk-2,0216119060474,1(from-trk-grp)”) in new stack
– Executing [0216119060474@trk-2:1] Set(“PJSIP/19-0000016e”, “_NTD=0216119060474”) in new stack
– Executing [0216119060474@trk-2:2] Gosub(“PJSIP/19-0000016e”, “trk-2-dial,0216119060474,1(from-trk-grp)”) in new stack
– Executing [0216119060474@trk-2-dial:1] NoOp(“PJSIP/19-0000016e”, “Trunk: 0049608191280”) in new stack
– Executing [0216119060474@trk-2-dial:2] NoOp(“PJSIP/19-0000016e”, “Dialing: 0216119060474”) in new stack
– Executing [0216119060474@trk-2-dial:3] Set(“PJSIP/19-0000016e”, “CDR(trunk)=2”) in new stack
– Executing [0216119060474@trk-2-dial:4] Set(“PJSIP/19-0000016e”, “SKIP_HANGUP_AUDIOS=no”) in new stack
– Executing [0216119060474@trk-2-dial:5] Gosub(“PJSIP/19-0000016e”, “sub-setup-call-type,s,1(outgoing,no)”) in new stack
– Executing [s@sub-setup-call-type:3] Gosub(“PJSIP/19-0000016e”, “s-outgoing,1(no)”) in new stack
– Executing [0216119060474@trk-2-dial:6] ExecIf(“PJSIP/19-0000016e”, “0?Set(CALLERID(all)=):”) in new stack
– Executing [0216119060474@trk-2-dial:7] Set(“PJSIP/19-0000016e”, “SKIP_HANGUP_AUDIOS=yes”) in new stack
– Executing [0216119060474@trk-2-dial:8] GotoIf(“PJSIP/19-0000016e”, “0?:after-val-sim-calls”) in new stack
– Goto (trk-2-dial,0216119060474,19)
– Executing [0216119060474@trk-2-dial:19] NoOp(“PJSIP/19-0000016e”, “”) in new stack
– Executing [0216119060474@trk-2-dial:20] Set(“PJSIP/19-0000016e”, “MAX_CALLS=10”) in new stack
– Executing [0216119060474@trk-2-dial:21] NoOp(“PJSIP/19-0000016e”, “Allowed Outgoing Simultaneous Calls: 10”) in new stack
– Executing [0216119060474@trk-2-dial:22] Set(“PJSIP/19-0000016e”, “GROUP()=trk-2”) in new stack
– Executing [0216119060474@trk-2-dial:23] GotoIf(“PJSIP/19-0000016e”, “0?:trk-conf”) in new stack
– Goto (trk-2-dial,0216119060474,27)
– Executing [0216119060474@trk-2-dial:27] NoOp(“PJSIP/19-0000016e”, “Configuring Trunk Parameters”) in new stack
– Executing [0216119060474@trk-2-dial:28] ExecIf(“PJSIP/19-0000016e”, “1?Set(CHANNEL(musicclass)=default):”) in new stack
– Executing [0216119060474@trk-2-dial:29] Set(“PJSIP/19-0000016e”, “__TRUNK_MOH_SET=yes”) in new stack
– Executing [0216119060474@trk-2-dial:30] Set(“PJSIP/19-0000016e”, “__TRKDIALOPTIONS=kKtr”) in new stack
– Executing [0216119060474@trk-2-dial:31] Set(“PJSIP/19-0000016e”, “ORIGINATOR=19”) in new stack
– Executing [0216119060474@trk-2-dial:32] Set(“PJSIP/19-0000016e”, “RING_TIME=90”) in new stack
– Executing [0216119060474@trk-2-dial:33] Set(“PJSIP/19-0000016e”, “CALLED=0216119060474”) in new stack
– Executing [0216119060474@trk-2-dial:34] Set(“PJSIP/19-0000016e”, “TRUNK_ENDPOINT=0049608191280”) in new stack
– Executing [0216119060474@trk-2-dial:35] Set(“PJSIP/19-0000016e”, “__CIDNUM=4960819263119”) in new stack
– Executing [0216119060474@trk-2-dial:36] Set(“PJSIP/19-0000016e”, “__CIDNAME=4960819263119”) in new stack
– Executing [0216119060474@trk-2-dial:37] Set(“PJSIP/19-0000016e”, “FORCE_RECORDING=no”) in new stack
– Executing [0216119060474@trk-2-dial:38] Set(“PJSIP/19-0000016e”, “FILTERED_NUMBER=0216119060474”) in new stack
– Executing [0216119060474@trk-2-dial:39] GotoIf(“PJSIP/19-0000016e”, “0?:post-fax”) in new stack
– Goto (trk-2-dial,0216119060474,42)
– Executing [0216119060474@trk-2-dial:42] NoOp(“PJSIP/19-0000016e”, “End Fax Section”) in new stack
– Executing [0216119060474@trk-2-dial:43] Dial(“PJSIP/19-0000016e”, “PJSIP/0216119060474@0049608191280,90,kKtrU(sub-call-recording^7e6ec33c5d155b8a^19^0216119060474^no)”) in new stack
– Called PJSIP/0216119060474@0049608191280
== Everyone is busy/congested at this time (1:0/0/1)
– Executing [0216119060474@trk-2-dial:44] GotoIf(“PJSIP/19-0000016e”, “0?:after-fax”) in new stack
– Goto (trk-2-dial,0216119060474,47)
– Executing [0216119060474@trk-2-dial:47] NoOp(“PJSIP/19-0000016e”, “End Fax Section”) in new stack
– Executing [0216119060474@trk-2-dial:48] NoOp(“PJSIP/19-0000016e”, “After Dial”) in new stack
– Executing [0216119060474@trk-2-dial:49] GotoIf(“PJSIP/19-0000016e”, “1?come-back”) in new stack
– Goto (trk-2-dial,0216119060474,51)
– Executing [0216119060474@trk-2-dial:51] Return(“PJSIP/19-0000016e”, “”) in new stack
– Executing [0216119060474@trk-2:3] GotoIf(“PJSIP/19-0000016e”, “1?come-back”) in new stack
– Goto (trk-2,0216119060474,5)
– Executing [0216119060474@trk-2:5] Return(“PJSIP/19-0000016e”, “”) in new stack
– Executing [s-1@cos-Administration-post:4] NoOp(“PJSIP/19-0000016e”, “Hangup Cause: 1, Dial Status: CHANUNAVAIL”) in new stack
– Executing [s-1@cos-Administration-post:5] ForkCDR(“PJSIP/19-0000016e”, “e”) in new stack
– Executing [s-1@cos-Administration-post:6] GotoIf(“PJSIP/19-0000016e”, “0?end_call”) in new stack
– Executing [s-1@cos-Administration-post:7] Gosub(“PJSIP/19-0000016e”, “sub-hangup-cause,s,1(1)”) in new stack
– Executing [s@sub-hangup-cause:1] NoOp(“PJSIP/19-0000016e”, “Executing Hangup Cause 1”) in new stack
– Executing [s@sub-hangup-cause:2] GotoIf(“PJSIP/19-0000016e”, “1?hangup”) in new stack
– Goto (sub-hangup-cause,s,10)
– Executing [s@sub-hangup-cause:10] Hangup(“PJSIP/19-0000016e”, “”) in new stack
== Spawn extension (sub-hangup-cause, s, 10) exited non-zero on ‘PJSIP/19-0000016e’
vitalpbx
CLI>
Check if your trunk is up and running. Additionally, you can use the SNGREP tool to see if there’s any other hint about why the call is being rejected by the provider.
