I have subscribed to and setup VitalPBX Multi Tenant and added 10 VitalPBX connect licenses. Got a tenant setup and assigned out the connect licenses. So far so good. Have my sip trunks setup, inbound and outbound routes working etc. But I am having an issue getting Webrtc to function. I have 1 client setup but cannot get another client to enable in extensions. My multitenant license is applied. I know I am just missing something, but could use a little help, or point me to a good document on Webrtc for 4.5.
Did you check if VitXi is selected in “External Add-ons” in the tenant’s settings under the “Settings” tab?
I did find that and it was selected.
Also, under addons if I click the Key icon it tells me it is under a licensing plan
I do have VitXi installed/enabled. and I have 1 license working. But when I try to enable WebRTC on a 2nd extension I get the error. I have also installed the Multi Tenant license which should give me 250 licenses I believe.
Not sure what happened but I can apply licenses now on the extensions. So we are good now.
