Having an issue with backups and restores since 4.5.1-1
When I run a backup that has recordings, the status bar moves almost gets almost to the end and then hangs and I finally get a Gateway Timeout Error.
Also on restoring (even a backup without recordings) I get the error.
This is happening on two different instances. Both running Debian 12, VPB 4.5.1-1, with plenty of space and resources. 20 Cores, 50GB Ram and 3 to 4 TB to free disk space.
Anyone else having or had this issue, and if you haven’t noticed; go check your automated backups and see if they are running.
Check your internet connection or your web browser… If you are using a Proxy on your internet connection turn it off and try again. Let me know if you need more help.
