I installled vitalpbx 3 latest version and did PJSTP trunk to grandstream HT813 with latest firmware. incoming call and outgoing are working fine. im using vitalpbx softphone. no hardphone.
while dialing outgoing call i can hear 2 ringtone then afterwards its a big silence but its actually ringing in the called number. because of this i cannot know whther the call is making or not.
May I know where im missing it.
Also FXS port not registering with vitalpbx after configuring with fxo port. its status shows registered in grandstream HT813 for fxo port but not fxs. but first fxs was showing registered. after changing sip default port of grandstream of fxs and fxo, fxs port never registered. fxs sip port is 5062 and fxo is 5060. vitalpbx im using PJSIP for fxo and SIP for fxs. where im missing here also
after some attempt I could install with latest vitalpbx mobile application with my samsung S21 FE. and its QR code worked fine. now i can hear ringtone while calling from it. so its something related to softphone
But same didnt happened with my Huawei p40 pro. its scan but not recognize the QR Code. may I know the reason?
initially when I did PJSIP with FXS it registered. but when i changed the FXO to 5060 it become like this. what im thinking now.
for FXO ill create second trunk. and reverse the port back and see how ti works
