Ghost Sip Trunk registration connections
Deleted SIP trunks (VAPI/Vox) still attempt to register, causing continuous 403 errors in logs despite removal over a week ago.
I’ve tried deleting/recreating trunks.
The issue persists after Asterisk restarts.
I suspect database remnants or cached configurations.
Is there a way to purge orphaned SIP registrations from the database?
How to clear Asterisk’s PJSIP cache in VitalPBX.
I think it’s stopping me from making outbound calls from Vapi?
[2025-07-11 05:11:56] NOTICE[974] res_pjsip/pjsip_distributor.c: Request ‘REGISTER’ from ‘sip:[email protected]’ failed for ‘44.238.177.138:5060’ (callid: 6847971a-d8b8-123e-d78c-0a6b2821a33f) - Failed to authenticate
[2025-07-11 05:11:57] NOTICE[974] res_pjsip/pjsip_distributor.c: Request ‘REGISTER’ from ‘sip:[email protected]’ failed for ‘44.238.177.138:5060’ (callid: 6890f1ec-d8b8-123e-d78c-0a6b2821a33f) - Failed to authenticate
[2025-07-11 05:11:57] NOTICE[974] res_pjsip/pjsip_distributor.c: Request ‘REGISTER’ from ‘sip:[email protected]’ failed for ‘44.238.177.138:5060’ (callid: 68918026-d8b8-123e-d78c-0a6b2821a33f) - Failed to authenticate
[2025-07-11 05:11:58] NOTICE[974] res_pjsip/pjsip_distributor.c: Request ‘REGISTER’ from ‘sip:[email protected]’ failed for ‘44.238.177.138:5060’ (callid: 69816770-d8b8-123e-d78c-0a6b2821a33f) - Failed to authenticate
[2025-07-11 05:12:18] NOTICE[974] res_pjsip/pjsip_distributor.c: Request ‘REGISTER’ from ‘sip:[email protected]’ failed for ‘44.238.177.138:5060’ (callid: 7529ef4a-d8b8-123e-d78c-0a6b2821a33f) - No matching endpoint found after 3 tries in 0.154 ms
[2025-07-11 05:12:18] NOTICE[974] res_pjsip/pjsip_distributor.c: Request ‘REGISTER’ from ‘sip:[email protected]’ failed for ‘44.238.177.138:5060’ (callid: 7529ef4a-d8b8-123e-d78c-0a6b2821a33f) - Failed to authenticate
[2025-07-11 05:12:18] NOTICE[974] res_pjsip/pjsip_distributor.c: Request ‘REGISTER’ from ‘sip:[email protected]’ failed for ‘44.238.177.138:5060’ (callid: 752a586e-d8b8-123e-d78c-0a6b2821a33f) - No matching endpoint found after 4 tries in 0.157 ms
What you are sharing is a failed registration request from extension device 2002
