Hi
Where can you change the External CID value on the Follow me?
In FreePBX and Elastix you have the options under follow me to Change the External CID Configuration to a Fixed CID value
I cant find that setting in VitalPBX and I need it for my call forwarding to work.
These are the options under Freepbx:
Change External CID Configuration
Mode:
Default
Fixed CID Value
Outside Calls Fixed CID Value
Use Dialed Number
Force Dialed Number
Fixed CID Value:
