Feature Code Issue with *95
Dialing *955000 should allow me to leave a voicemail for Extension 5000 without ringing the extension.
The error message of unable to complete your call as dialled i returned audibly.
The consolde log is:
Connected to Asterisk 18.16.0 currently running on mercury66 (pid = 898)
– Executing [*955000@cos-all:1] NoOp(“PJSIP/9966-00000058”, “More than on digit pattern”) in new stack
– Executing [*955000@cos-all:2] Gosub(“PJSIP/9966-00000058”, “s,1(*955000)”) in new stack
– Executing [s@cos-all:1] Set(“PJSIP/9966-00000058”, “EXTENSION=*955000”) in new stack
– Executing [s@cos-all:2] NoOp(“PJSIP/9966-00000058”, “Dialing *955000 from 9966”) in new stack
– Executing [s@cos-all:3] Gosub(“PJSIP/9966-00000058”, “sub-set-global-vars,s,1(2ab4962e827a2545,*955000,parking-1)”) in new stack
– Executing [s@sub-set-global-vars:1] NoOp(“PJSIP/9966-00000058”, “Setting Global Vars”) in new stack
– Executing [s@sub-set-global-vars:2] Set(“PJSIP/9966-00000058”, “TENANT_PATH=2ab4962e827a2545”) in new stack
– Executing [s@sub-set-global-vars:3] Set(“PJSIP/9966-00000058”, “PREFIX=”) in new stack
– Executing [s@sub-set-global-vars:4] Set(“PJSIP/9966-00000058”, “__PICKUPMARK=*955000”) in new stack
– Executing [s@sub-set-global-vars:5] Set(“PJSIP/9966-00000058”, “__PARKINGLOT=parking-1”) in new stack
– Executing [s@sub-set-global-vars:6] Set(“PJSIP/9966-00000058”, “__DYNAMIC_FEATURES=custom-features”) in new stack
– Executing [s@sub-set-global-vars:7] Set(“PJSIP/9966-00000058”, “ICALL=no”) in new stack
– Executing [s@sub-set-global-vars:8] Return(“PJSIP/9966-00000058”, “”) in new stack
– Executing [s@cos-all:4] Gosub(“PJSIP/9966-00000058”, “sub-set-call-vars,s,1(2ab4962e827a2545,*955000,1,cos-all,ARS-all)”) in new stack
– Executing [s@sub-set-call-vars:1] NoOp(“PJSIP/9966-00000058”, “Setting Call Vars”) in new stack
– Executing [s@sub-set-call-vars:2] Set(“PJSIP/9966-00000058”, “_TENANT=2ab4962e827a2545”) in new stack
– Executing [s@sub-set-call-vars:3] Set(“PJSIP/9966-00000058”, “_CALL_DESTINATION=*955000”) in new stack
– Executing [s@sub-set-call-vars:4] Set(“PJSIP/9966-00000058”, “_COS_ID=1”) in new stack
– Executing [s@sub-set-call-vars:5] Set(“PJSIP/9966-00000058”, “_COS_NAME=cos-all”) in new stack
– Executing [s@sub-set-call-vars:6] Set(“PJSIP/9966-00000058”, “__TRANSFER_CONTEXT=cos-all”) in new stack
– Executing [s@sub-set-call-vars:7] Set(“PJSIP/9966-00000058”, “_ARS=ARS-all”) in new stack
– Executing [s@sub-set-call-vars:8] Set(“PJSIP/9966-00000058”, “CDR(tenant)=vitalpbx”) in new stack
– Executing [s@sub-set-call-vars:9] Set(“PJSIP/9966-00000058”, “CDR(destination)=*955000”) in new stack
– Executing [s@sub-set-call-vars:10] Set(“PJSIP/9966-00000058”, “CDR(trunk)=”) in new stack
– Executing [s@sub-set-call-vars:11] Set(“PJSIP/9966-00000058”, “CDR(did)=”) in new stack
– Executing [s@sub-set-call-vars:12] Set(“PJSIP/9966-00000058”, “__CALLID=1681075532.320”) in new stack
– Executing [s@sub-set-call-vars:13] NoOp(“PJSIP/9966-00000058”, “Channel Type: PJSIP”) in new stack
– Executing [s@sub-set-call-vars:14] ExecIf(“PJSIP/9966-00000058”, “1?Set(__PJSIP_CALLID=1653028892-18851-4@BAA.BAE.BH.BDD)”) in new stack
– Executing [s@sub-set-call-vars:15] ExecIf(“PJSIP/9966-00000058”, “0?Set(CHANNEL(language)=)”) in new stack
– Executing [s@sub-set-call-vars:16] ExecIf(“PJSIP/9966-00000058”, “0?Set(CHANNEL(language)=)”) in new stack
– Executing [s@sub-set-call-vars:17] Return(“PJSIP/9966-00000058”, “”) in new stack
– Executing [s@cos-all:5] Gosub(“PJSIP/9966-00000058”, “sub-construct-cid,s,1”) in new stack
– Executing [s@sub-construct-cid:1] NoOp(“PJSIP/9966-00000058”, “Building CID”) in new stack
– Executing [s@sub-construct-cid:2] Set(“PJSIP/9966-00000058”, “_CALL_SOURCE=9966”) in new stack
– Executing [s@sub-construct-cid:3] Set(“PJSIP/9966-00000058”, “_CS=9966”) in new stack
– Executing [s@sub-construct-cid:4] GotoIf(“PJSIP/9966-00000058”, “0?return”) in new stack
– Executing [s@sub-construct-cid:5] Gosub(“PJSIP/9966-00000058”, “sub-get-device-tree,s,1”) in new stack
– Executing [s@sub-get-device-tree:1] NoOp(“PJSIP/9966-00000058”, “Configuring Device Tree”) in new stack
– Executing [s@sub-get-device-tree:2] Set(“PJSIP/9966-00000058”, “DEV_TECHNOLOGY=PJSIP”) in new stack
– Executing [s@sub-get-device-tree:3] GosubIf(“PJSIP/9966-00000058”, “0?s-local,1”) in new stack
– Executing [s@sub-get-device-tree:4] GotoIf(“PJSIP/9966-00000058”, “0?return”) in new stack
– Executing [s@sub-get-device-tree:5] GotoIf(“PJSIP/9966-00000058”, “1?pjsip”) in new stack
– Goto (sub-get-device-tree,s,9)
– Executing [s@sub-get-device-tree:9] NoOp(“PJSIP/9966-00000058”, “A PJSIP”) in new stack
– Executing [s@sub-get-device-tree:10] Set(“PJSIP/9966-00000058”, “DEV_USER=9966”) in new stack
– Executing [s@sub-get-device-tree:11] Goto(“PJSIP/9966-00000058”, “build_interface”) in new stack
– Goto (sub-get-device-tree,s,13)
– Executing [s@sub-get-device-tree:13] Set(“PJSIP/9966-00000058”, “_INTERFACE=PJSIP/9966”) in new stack
– Executing [s@sub-get-device-tree:14] Set(“PJSIP/9966-00000058”, “DEV_TREE=devices/PJSIP/9966”) in new stack
– Executing [s@sub-get-device-tree:15] Return(“PJSIP/9966-00000058”, “”) in new stack
– Executing [s@sub-construct-cid:6] GotoIf(“PJSIP/9966-00000058”, “0?return”) in new stack
– Executing [s@sub-construct-cid:7] Set(“PJSIP/9966-00000058”, “_CALL_SOURCE=9966”) in new stack
– Executing [s@sub-construct-cid:8] Set(“PJSIP/9966-00000058”, “_CS=9966”) in new stack
– Executing [s@sub-construct-cid:9] Set(“PJSIP/9966-00000058”, “EXTENSION_INTERNAL_CID=“9966” <9966>”) in new stack
– Executing [s@sub-construct-cid:10] ExecIf(“PJSIP/9966-00000058”, “1?Set(CALLERID(all)=“9966” <9966>)”) in new stack
– Executing [s@sub-construct-cid:11] Set(“PJSIP/9966-00000058”, “_CID_CONSTRUCTED=yes”) in new stack
– Executing [s@sub-construct-cid:12] NoOp(“PJSIP/9966-00000058”, “”) in new stack
– Executing [s@sub-construct-cid:13] Set(“PJSIP/9966-00000058”, “CDR(source)=9966”) in new stack
– Executing [s@sub-construct-cid:14] Return(“PJSIP/9966-00000058”, “”) in new stack
– Executing [s@cos-all:6] Gosub(“PJSIP/9966-00000058”, “set-global-tenant-vars,s,1”) in new stack
– Executing [s@set-global-tenant-vars:1] NoOp(“PJSIP/9966-00000058”, “Setting Global Vars for vitalpbx Tenant”) in new stack
– Executing [s@set-global-tenant-vars:2] Set(“PJSIP/9966-00000058”, “__TENANT_PATH=2ab4962e827a2545”) in new stack
– Executing [s@set-global-tenant-vars:3] Set(“PJSIP/9966-00000058”, “__TENANT_PREFIX=”) in new stack
– Executing [s@set-global-tenant-vars:4] Set(“PJSIP/9966-00000058”, “__QUEUE_AGENTS_CONTEXT=queue-call-to-agents”) in new stack
– Executing [s@set-global-tenant-vars:5] Set(“PJSIP/9966-00000058”, “__FOLLOWME_CONTEXT=ext-followme”) in new stack
– Executing [s@set-global-tenant-vars:6] Set(“PJSIP/9966-00000058”, “__HINTS_CONTEXT=extension-hints”) in new stack
– Executing [s@set-global-tenant-vars:7] Set(“PJSIP/9966-00000058”, “__DEFAULT_COS=cos-all”) in new stack
– Executing [s@set-global-tenant-vars:8] Return(“PJSIP/9966-00000058”, “”) in new stack
– Executing [s@cos-all:7] GotoIf(“PJSIP/9966-00000058”, “0?local-dialing”) in new stack
– Executing [s@cos-all:8] NoOp(“PJSIP/9966-00000058”, “Check if is an Emergency Call”) in new stack
– Executing [s@cos-all:9] GotoIf(“PJSIP/9966-00000058”, “0?emergency-calls,*955000,1”) in new stack
– Executing [s@cos-all:10] Gosub(“PJSIP/9966-00000058”, “sub-lockphone-check,s,1”) in new stack
– Executing [s@sub-lockphone-check:1] NoOp(“PJSIP/9966-00000058”, “SUB: LOCK PHONE CHECK”) in new stack
– Executing [s@sub-lockphone-check:2] GotoIf(“PJSIP/9966-00000058”, “0?unlock”) in new stack
– Executing [s@sub-lockphone-check:3] GotoIf(“PJSIP/9966-00000058”, “0?unlock”) in new stack
– Executing [s@sub-lockphone-check:4] GotoIf(“PJSIP/9966-00000058”, “0?unlock”) in new stack
– Executing [s@sub-lockphone-check:5] GotoIf(“PJSIP/9966-00000058”, “0?unlock”) in new stack
– Executing [s@sub-lockphone-check:6] GotoIf(“PJSIP/9966-00000058”, “0?:unlock”) in new stack
– Goto (sub-lockphone-check,s,12)
– Executing [s@sub-lockphone-check:12] Return(“PJSIP/9966-00000058”, “”) in new stack
– Executing [s@cos-all:11] Gosub(“PJSIP/9966-00000058”, “sub-local-dialing,s,1”) in new stack
– Executing [s@sub-local-dialing:1] NoOp(“PJSIP/9966-00000058”, “Trying to determine if is a local extension”) in new stack
– Executing [s@sub-local-dialing:2] GotoIf(“PJSIP/9966-00000058”, “0?:return”) in new stack
– Goto (sub-local-dialing,s,5)
– Executing [s@sub-local-dialing:5] Return(“PJSIP/9966-00000058”, “”) in new stack
– Executing [s@cos-all:12] GotoIf(“PJSIP/9966-00000058”, “0?end-call”) in new stack
– Executing [s@cos-all:13] Goto(“PJSIP/9966-00000058”, “cos-all-post,*955000,1”) in new stack
– Goto (cos-all-post,*955000,1)
– Channel ‘PJSIP/9966-00000058’ sent to invalid extension: context,exten,priority=cos-all-post,*955000,1
– Executing [i@cos-all-post:1] NoOp(“PJSIP/9966-00000058”, “Invalid dial on post section”) in new stack
– Executing [i@cos-all-post:2] ForkCDR(“PJSIP/9966-00000058”, “e”) in new stack
– Executing [i@cos-all-post:3] ExecIf(“PJSIP/9966-00000058”, “0?Hangup():”) in new stack
– Executing [i@cos-all-post:4] Goto(“PJSIP/9966-00000058”, “invalid-dest-cos,s,1”) in new stack
– Goto (invalid-dest-cos,s,1)
– Executing [s@invalid-dest-cos:1] NoOp(“PJSIP/9966-00000058”, “Invalid Route Dialed in COS”) in new stack
– Executing [s@invalid-dest-cos:2] GotoIf(“PJSIP/9966-00000058”, “0?end”) in new stack
– Executing [s@invalid-dest-cos:3] GotoIf(“PJSIP/9966-00000058”, “0?end”) in new stack
– Executing [s@invalid-dest-cos:4] Progress(“PJSIP/9966-00000058”, “”) in new stack
> 0x7fd92c07f8f0 – Strict RTP learning after remote address set to: 100.104.17.133:14004
– Executing [s@invalid-dest-cos:5] Playback(“PJSIP/9966-00000058”, “silence/1&cannot-complete-as-dialed&check-number-dial-again,noanswer”) in new stack
– <PJSIP/9966-00000058> Playing ‘silence/1.ulaw’ (language ‘en’)
> 0x7fd92c07f8f0 – Strict RTP qualifying stream type: audio
> 0x7fd92c07f8f0 – Strict RTP switching source address to 174.216.177.92:5183
– <PJSIP/9966-00000058> Playing ‘cannot-complete-as-dialed.ulaw’ (language ‘en’)
– <PJSIP/9966-00000058> Playing ‘check-number-dial-again.ulaw’ (language ‘en’)
> 0x7fd92c07f8f0 – Strict RTP learning complete - Locking on source address 174.216.177.92:5183
– Executing [s@invalid-dest-cos:6] Hangup(“PJSIP/9966-00000058”, “”) in new stack
== Spawn extension (invalid-dest-cos, s, 6) exited non-zero on ‘PJSIP/9966-00000058’
The wiki is a bit unclear. It’s *95*. So the correct number to dial would be *95*5000
Actually the wiki online is pretty clear this time:
*95 – Send Voicemail Message, allows you to dial any extension and leave a voicemail. For example, when dialing *95*2492, you can leave a voicemail message to extension 2492. The feature must be enabled on the Feature Category associated to the extension.
This should be
*95* – Send Voicemail Message
Thank you for your response. Because I have visual limitations, reading the Wiki is troublesome and there is no PDF version for download for me to use a screen reader. Whether or not the Wiki is write, the feature code list is missing the second “*”
