Vitapbx 4.0.6-3
Virtual Faxes: 4.0.1-2
Max Retries not working. Set it to 2 or 5.
It only tries 1 time.
The call dropped prematurely
I sent another Fax from the gui: Timed out waiting for initial communication
Both only 1 try.
Vitapbx 4.0.6-3
Both only 1 try.
This is something that Asterisk does by default. You should check the logs to see if Asterisk is considering the call as processed!
Why would it not try again? Isn’t this what a retry is for?
And as mentioned, it had been a different error messages when i tried it a different time. But again: only 1 try.
That’s something decided by Asterisk. Again, check the logs!
https://docs.asterisk.org/Configuration/Interfaces/Asterisk-Call-Files/
