Failed authentication
Hello.
I installed VPBX, created PJSIP Extension and trying to connect soft phone Blink, getting auth error. Some years ago I was using Elastix and it was much easier. As I understand PJSIP protocol differs from SIP, but Blink has the possibility to create only SIP account. I checked settings and see PJSIP on 5060 port, SIP on 5063. I tried to set in Blink [email protected]:5063, but no luck, still failed auth. What options I have? Should I use another soft phone? Any recommendations with PJSIP support? Can I move PJSIP to another port and SIP to default 5060?
Are you trying to connect the Blink softphone using a Tenant account?
what is tenant account? can’t find it in wiki. I just created an extension 111 and trying to connect Blink using the account [email protected] and see wrong auth in logs despite of correct password.
Are you using the Multi-Tenant module?
Is IP 192.168.1.1 valid? As far as I understand, the first IP address is assigned to the router.
Can’t find what is Multi-Tenant module in wiki too. I use default configuration, just installed VPBX from ISO. Yes, 192.168.1.1 is the VPBX VM IP.
Any ideas how to resolve this?
What do you see in the Asterisk CLI?
You sure I need to use CLI? I just created Extension in web GUI and trying to connect softphone Blink. No idea what is the difference between PJSIP and SIP. Should I use especial PJSIP softphone?
