The PBX we are coming from (a very popular asterisk based PBX…) has under the extension advanced tab the following options as “extension failover”:
The default for all is voicemail, but we set the destination if unreachable to go to its FollowMe. (even if FollowMe is normally disabled, force FM will “temporarily” enable FollowMe)
This is super helpful when an end-user’s device is offline.
Please implement such a functionality.
In case it isn’t clear what these options are:
1 No Answer
Meaning: Call is routed to when the call is not answered on an otherwise idle phone. If the phone is in use and the call is simply ignored, then the busy destination will be used.
Destination: Send to voicemail unavailable greeting.
2 Busy
Meaning: Call is routed to when the phone is busy or the call is rejected by the user. This destination is also used on an unanswered call if the phone is in use and the user chooses not to pickup the second call.
Destination: Send to voicemail busy greeting.
3 Not Reachable
Meaning: Call is routed to when the phone is offline, such as a softphone currently off or a phone unplugged.
Destination: Force follow Me
Also, in case you didn’t see, they also allow you to set a Caller ID prefix, which is very helpful if we send the call to another extension, so they understand that this is a forwarded call.
