I have a Yealink EXP43 expansion module. How is this programmed in version 4? I don’t see anything under provisioning to program this.
Does it work in v3 and not in v4?
Yes Expansion modules on Yealink phones work in V3
V4 has no provisioning for Expansion modules thru the gui
At this time in V4.0.2-1 I have had to manually add keys for addon units in the custom section with something like this:
expansion_module.1.key.1.label = Kathy
expansion_module.1.key.1.line = 1
expansion_module.1.key.1.type = 16
expansion_module.1.key.1.value = 302
expansion_module.1.key.2.label = Kent
expansion_module.1.key.2.line = 1
expansion_module.1.key.2.type = 16
expansion_module.1.key.2.value = 303
expansion_module.1.key.3.label = Joe
expansion_module.1.key.3.line = 1
expansion_module.1.key.3.type = 16
expansion_module.1.key.3.value = 304
expansion_module.1.key.4.label = Board Room
expansion_module.1.key.4.line = 1
expansion_module.1.key.4.type = 16
expansion_module.1.key.4.value = 305
expansion_module.1.key.5.label = Tony
expansion_module.1.key.5.line = 1
expansion_module.1.key.5.type = 16
expansion_module.1.key.5.value = 306
Thank you! Does the type = 16 designate a BLF key?
Yes type = 16 is a BLF key
Thank you. I appreciate your help.
I changed this to the correct category.
Let’s hope the devs pick up on this.
