Exchange and Gmail calendar integration
I would like to suggest, that users can integrate/add their calendar, so there is a sync between calendar and the PBX
  1. users can choose routing based on calendar
  2. via the operator panel, and vixit it should be possible to see the status of the user including calendar status
We are ready to sponsor such feature
If you are seriously considering sponsoring a add-on, consider sending an email to [email protected] as well.
done, email sent as requested
