Whenever I try to add a phone (via scan network) I get an Exception:
Tried with two different fresh VitalPBX 4 installations and SNOM D385 / Poly VX411 Phones.
I fill all the parameters nessecary, hit save and BAM!
Same happens when I edit (not create) a Snom D385 Template (doesn’t happen with a poly template)
Correction: It doesn’t happen when I try to provision Poly Phones. Snom only…
Even when i try to add a snom phone manually in the provisioning menu this happens. So i don’t have to go through the scan network route…
The Phones are created anyway but it doesn’t work at all. As soon as I try to edit the phone created the same error appears
