Fresh Install, Port 80 and 443 are active, only vitalpbx is ON.
VitalPBX 3.1.5-3
Asterisk 18.6.0-2
I tried different hostnames, that resolve to my IP, different country.
Geo Firewall is active, only blocking China.
Reinstall twice, same error
Any ideas ?
miguel
January 19, 2022, 2:47pm
2
Search in the path β/var/log/vitalpbx β the latest log of Letβs Encrypt. The file has the format βlets_encrypt-2021-01-19.log β
@miguel
[2022-01-19 0:25:59.107336] [debug] POST response received
request: 'POST https://acme-v02.api.letsencrypt.org/acme/acct/370608510'
header: 'HTTP/1.1 200 OK
Server: nginx
Date: Wed, 19 Jan 2022 05:25:59 GMT
Content-Type: application/json
Content-Length: 893
Connection: keep-alive
Boulder-Requester: 370608510
Cache-Control: public, max-age=0, no-cache
Link: <https://acme-v02.api.letsencrypt.org/directory>;rel="index"
Link: <https://letsencrypt.org/documents/LE-SA-v1.2-November-15-2017.pdf>;rel="terms-of-service"
Replay-Nonce: 0001RXnhMzl8rDGsuTQTnqSiXQnvnBtX-l5JpsbAsgL0_nE
X-Frame-Options: DENY
Strict-Transport-Security: max-age=604800
status: 200
body: array(
'key' => array(
'kty' => 'RSA',
'n' => '1njpp_-xNCqXh8bkBIpYsfGuH_pbCabxqoEh40FIUtLKoDOgpiYAxIh_e6enCwPHzCMZbpPcjE-ROdvnNmSRlEMf6v15EZWvmi8ych6LzR_m5OMgCoq1zrpb6fL9ymxXlX0ZrL$
'e' => 'AQAB',
'contact' => array(
0 => 'mailto:[email protected] ',
'initialIp' => '51.222.161.151',
'createdAt' => '2022-01-19T05:25:58Z',
'status' => 'valid',
[2022-01-19 0:25:59.108144] [info] LEClient finished constructing
[2022-01-19 0:25:59.109731] [info] No order found for 'vital.MYDOMAIN.ca'. Creating new order.
[2022-01-19 0:25:59.386130] [debug] POST response received
request: 'POST https://acme-v02.api.letsencrypt.org/acme/new-order'
header: 'HTTP/1.1 100 Continue
HTTP/1.1 400 Bad Request
Server: nginx
Content-Type: application/problem+json
Content-Length: 133
Replay-Nonce: 0001Ree59JwEB3pSpOUiWHQZmhuO-xCssGXfRlyBnMT7k1Y
status: 400
body: array(
'type' => 'urn:ietf:params:acme:error:malformed',
'detail' => 'NewOrder request did not specify any identifiers',
'status' => 400,
[2022-01-19 0:25:59.386795] [error] Invalid response
url: 'https://acme-v02.api.letsencrypt.org/acme/new-order'
method: 'POST'
status: 400
Server: nginx
Content-Length: 133
body: '{
"type": "urn:ietf:params:acme:error:malformed",
"detail": "NewOrder request did not specify any identifiers",
"status": 400
miguel
January 19, 2022, 3:22pm
4
Can you share a screenshot to see how you are defining the domain in the GUI?
having the exact same issue
miguel
January 19, 2022, 3:55pm
7
Try disabling all the firewalls on VitalPBX, then try creating the cert again.
Enter the hostname in subdomain box.
If you have any subdomain enter that in subdomain. Else simply enter the same hostname in hostname and subdomain that will resolve this issue.
system
Closed
February 18, 2022, 7:07pm
9
