hello, have you planned to integrate the dect w80 multicell yealink? if it is not in progress, can you guide me in first step creating the model?
Up
how to create a new model in the new privisionning systems
You can essentially use any existing Yealink template and copy the provisioning config from the W80 and add the variables at it’s necessary sections.
The problem will be the number of lines limited by the source model.
Do it all from the custom tab
