Enabled 2FA on Admin and Locked Out
I enabled the 2FA on the admin account and clicked SAVE.
Nothing happened when enabling it, so I thought once its enabled I should log out and log back in to configure it. Well that was a huge mistake and yes I should have probably done this on a test account first but I didn’t!
So HELP - how do I remove 2FA and get back into the admin account.
I have root ssh access at least…
You can execute the command below to disable the 2FA.
vitalpbx disable-2FA admin
About the setup, you must click on the blue button at the bottom bar after enabling the 2FA to configure it in your Authenticator App.
Now I know why it failed on me… I don’t have that blue box…
After clicking “Update” in the user form, you will see that blue button
Thank you so much!! I am sure this will save someone else too!
That worked! Phew… and also got my one plan activated too.
Now for the easy stuff…
