Is there a way to edit the configuration of extensions directly from the CLI ? I do not have access to the Web GUI right now and I need to change some names so I was wondering if this was possible.
I found some .conf files I could edit in /etc/asterisk/vitalpbx. Can I just edit these and reload Asterisk in order for my modifications to take effect ?
Config files are created from database values, so while you can edit the values directly next time you reload from the gui, the system will re-create the config files with values from the database so your changes will be lost.
