Disiprouter and VitalPBX issue
Hi there,
I followed the help guide provided by Vital for implementing dsiprouter.
So, I seem to be struggling slightly with routing.
When I attempt to make an inbound call, I can see the Invite come from the sip trunk but it doesn’t go anywhere after this. It’s like there’s not routing set up.
However, I have followed the instructions, setup my Endpoint Group and Domain and defined the PBX etc.
There’s no mention of inbound routes but I assume I had to set this up with the DID and route to the group but it doesn’t route at all.
I’ve definited
The PBX and proxy are sat behind NAT on different subnets. They’re able to talk to eachother and I have defined local networks under PJSIP settings and also the public IP.
Under sngrep, it shows the correct NAT IP of what I have defined in both inbound and outbound NAT for the PBX and proxy.
I think I’m close but not close enough.
Would anybody be able to share some knowledge of what I may have missed? Or share a few screenshots of a working setup?
What version of dsiprouter did you install? With the most recent version FPBX, cousin of VitalPBX, we have experienced some issues with dsiprouter simultaneously handling proxying registrations and trunks primarily because both happen on port 5060 pjsip.
